Results 1 to 26 of 26
Thread: 86 civic dx overheating why???
    Oct 2009
    ellijay, GA
    Angry 86 civic dx overheating why???
    I have a bone stock 1986 honda civic dx 5 spd and it keeps over heating while on the highway doing around 70-80 i have replaced the cooling fan, thermasta and flushed and replaced the fluids. and it still over heats for some reason does eny one know why????? please help me out pm me answers of just post it on here.. thanks
    Apr 2009
    warner robins
    its probly leaking somewhere just pressure test it and see where its leaking
    your mom loves me
    barrow county
    did the engine lock up or did you stop before it lock up?
    if everything is checked. i notice some people dont check this but, the termo sensor goes bad over time and your ecu think that its over heating but really its not
    Oct 2009
    ellijay, GA
    mine is actually not hooked up its just when my car runs hot going down the highway it putters and trys to stall out and their is a huge loss in power
    Quote Originally Posted by blue_gt View Post
    Oct 2009
    ellijay, GA
    the fluid is never low its toped off and was for over a week. idk im confused with this lil car
    Quote Originally Posted by 88civic_hatc View Post
    Do a compression and leakdown to see if your headgasket is leaking. If you are loosing fluid and you cant figure out where its going this may be it. It may be the waterpump but they usually leak when they go bad.
    Custom Tuning By Daniel Willie.
    Parts, Fabrication, Race Car Prep
    770-319-9605 or [email protected]
    barrow county
    he said hes not losing fluid, its topped off
    Oct 2009
    ellijay, GA
    yes its all toped off no water in the oil as well but still over heats when on hills or around 70mph. im more than confused on this. how cna i do a pressure test to see if its the head gasket???
    Oct 2008
    its not losing fluids, but overheats at high speed = time for some boost
    Certified Gearhead JuStCrUzIn's Avatar
    cashville
    Quote Originally Posted by k3tsurui View Post
    Apr 2009
    warner robins
    is the fan coming on
    your mom loves me
    IA Sponsor JJSPEC Racing's Avatar
    www.jjspec.com Macon, Ga
    Radiator may be clogged up. I know you flushed it, but there is only so much that will do for you. May want to pull it and send it to a rad shop to be "rodded out" as it probably is a brass radiator. Or better yet put a new one in it since that one is pushing 25 years.
    JJSPEC RACING - Central Ga's source for performance parts,
    fabrication, tuning, general repair and a whole lot more! 478 621 5000
    Oct 2009
    ellijay, GA
    after basic im wonting to do a boosted b18 swap but thats just a dream atm
    Oct 2009
    ellijay, GA
    I installed a new fan and its on a switch. i turn it on when the car is on.
    Oct 2009
    ellijay, GA
    could it be a blown head gasket? or would it have to leak fluids?
    Quote Originally Posted by jjmastertech View Post
    ^^^this
    if the car runs ok temp @ idle, but hot when driving (esp highway) the rad cannot flow much anymore. getting it cleaned out can work, but honda rad material is so thin you may end up w/ a hole when it's all said and done. plus, honda rad are pretty cheap. make sure the fan isn't wired up backward stalling the air coming through while you're moving.
    HONDATA DEALER/TUNER
    NISSAN REALTIME-NISTUNE
    Chickens Eat Eggs
    south side hoe
    might be a faulty thermostat... buy the fail safe thermostat its like 12 bucks!!
    Chickens Eat Eggs
    south side hoe
    is ur fan kicking on?? and heat working? could be a bad fan or maybe the fan switch or thermostat switch...
    Chickens Eat Eggs
    south side hoe
    Quote Originally Posted by laokid View Post
    oh nvm u have a switch for the fan...hmm maybe your radiator is clogged up...
    sandy springs
    Quote Originally Posted by scttydb411 View Post
    ^^^this
    Im going to agree. I had the same problem at work. A flush wont always fix a clogged radiator. With the age, time, and driving of the vehicle Id go ahead and replace it. I replaced a fan, thermostat, coolant flush, and it was still over heating. I replaced the radiator and all was fine. But if youve been running it hot which apparently you have since u said it ran like crap when hot, your head gasket may have issues now to. Leak down test would answer that question.
    Oct 2009
    ellijay, GA
    how do i do a leak down test?
    Quote Originally Posted by Marta Mike View Post
    sandy springs
    You will need the correct tool to perform this. Google "leak down tester"
    sweetspeed Mr. Fix-it.'s Avatar
    Musella, Ga
    i just had the same problem you are having. it was indeed a blown head gasket. i had the same motor and everything i beleive. d15b7? when i changed it out i put a z6 head on it and a new head gasket and i havent had the problem since.
    Musella, Ga
    oh, by the way. if you want to see if it is a blown head gasket just take off the radiator cap and start up the car. if anifreeze blows out then its definately blown.
    Oct 2009
    ellijay, GA
    thanks im def going to replace it.... how much is a dif head??
    Quote Originally Posted by Mr. Fix-it. View Post
    Musella, Ga
    well i got my head when i bought the car. a used head from honda parts connection is like 250 dollars. i got mine rebuilt for 266.
