Thread: Brake issue 92 accord
    IA Member rexguy478's Avatar
    macon ga
    Default Brake issue 92 accord
    Have a brake fluid leak and found where it is at (ABS reservoir). I have to fill brake fluid up about every 50 miles cause it keeps leaking out the abs reservoir cap. Replaced the cap and there are no cracks in it or the reservoir anywhere. There are no leaks anywhere else. Brakes have been bleed a few times correctly and everything is tight on the whole brake system. Entire system has been checked, double checked and triple checked. Could there be anything causing to much pressure causing it to leak from the cap on the abs or how do I find out whats causing this?
    see if your resrvoir is leaking on the back side
    macon ga
    Its leaking from the cap of the abs reservoir only.
    macon ga
    Does anyone have any idea? Please help me! I dont normally have to ask for help when it comes to a car but this one has me pulling my hair out and has been for the past month now.
    macon ga
    Does anyone know of or has heard of the dreaded ABS modulator leak??? I read this and have no idea about that or what it does really. Any help will be greatly appreciated.
