Results 1 to 7 of 7
Thread: transmission problem
    Crash
    Snellville, GA
    Unhappy transmission problem
    so im drivin home from work and i start getting this grinding noise from my transmission. it comes and goes but it gets worse wen ur driving. anybody have any ideas wat it could be and how much it could cost to fix. this is my 98 integra with b18 and y80 tranny if it helps any. thanks.
    1993 Honda Civic EX
    1993 Acura Integra
    1998 DB7 Integra
    1989 Toyota Supra
    1993 Toyota Supra
    Crash
    Snellville, GA
    ok so i just realized something with my tranny. if i sit here and just hold down my clutch it doesm+ make the grinding noise. +he second i let off the clutch the grinding noise comes back
    1993 Honda Civic EX
    1993 Acura Integra
    1998 DB7 Integra
    1989 Toyota Supra
    1993 Toyota Supra
    80 hp bullet
    Default hey
    same thing here but with an s80 transmission, mine felt like it took a huge dump today and now when i let go of the clutch it feels like it is in gear and it just stalls out as if it were in 5th gear or something.
    Jun 2009
    I had the same exact problem on my gsr tranny. It could be the front input shaft bearing thats going out, if that doesnt fix it then the gears might be fucked up. I replaced the bearing in my tranny and it was still making noise. Then we found out the gears were out so I had to replace the whole transmission. I would just get a good used cheap tranny unless you can do it yourself.
    Hope this helps you and good luck
    Crash
    Snellville, GA
    damn, i had a feeling that was what i would have to do. should i get the same tranny or could i upgrade to something better?
    1993 Honda Civic EX
    1993 Acura Integra
    1998 DB7 Integra
    1989 Toyota Supra
    1993 Toyota Supra
    Jun 2009
    You could go either gsr tranny or si tranny to upgrade. They are both stronger then the ls tranny, gsr the strongest of 2. The downside is that they both are shorter in gears and get less gas mileage. Also you wouldnt get much of high end power with the ls motor cuz its low power and good amount of torque. If ur going to do a lot of highway driving then stick with ls tranny. If not, well you can have fun with gsr or si tranny.
    Crash
    Snellville, GA
    sweet gsr tranny it is, just wanted to make sure it would work b4 i actually got it. thanx!
    1993 Honda Civic EX
    1993 Acura Integra
    1998 DB7 Integra
    1989 Toyota Supra
    1993 Toyota Supra
