Results 1 to 32 of 32
Thread: Transmission Problems
    IS300 NEMO's Avatar
    We Fuckin...
    Default Transmission Problems
    transmission is locking me out of gears at high rpms(7000-8500). it shifts fine at lower rpms(>7000).
    what could this be? synchronizers? bearings?
    1/2 Fast Motorsports highspeed's Avatar
    Gardendale AL
    synchro's.......but you might want to give some more info about which car it is, what transmission, clutch, etc............
    brandon you are the man! btw i got another 240 lol
    IS300 NEMO's Avatar
    We Fuckin...
    its a honda civic with a honda transmisson
    Most likely its your syncros. Does it do it in all gears? Try a fluid change first.
    IS300 NEMO's Avatar
    We Fuckin...
    mainly 4th but it did it in 3rd the other night.
    Yep, especially when its gear specific its most likely the syncros. But 3/4 do also share a shift fork, its possible you've got a bent fork.
    Quote Originally Posted by highspeed View Post
    I would consider this to be the synchro sleeves (hubs), but I would only know by taking it apart. Or even the actuall teeth on said gears.
    IS300 NEMO's Avatar
    We Fuckin...
    i know for a fact that the bearing is bad #15
    IS300 NEMO's Avatar
    We Fuckin...
    what did it do heat up and lock up?
    IS300 NEMO's Avatar
    We Fuckin...
    i was racing and when i shifted to 3rd it locked me out then rpms went down and it went into gear then when i shifted to 4th it did the same thing.
    when i am just driving it shifts fine
    IS300 NEMO's Avatar
    We Fuckin...
    could having to much fluid in the tranny cause this problem?
    ATL represent
    Nope
    syncros
    And sleeves
    time for a rebuild
    I'd check the gears gor wear and tolerances also
    I had this problem in 3rd/4th in my eclipse. It was the synchro and 3rd/4th shift fork. I heard that resting your hand on the gear shift while in a gear (specifically if its one of the lower ones of the gate) that it can cause wear to the fork. Not sure how true this is.
    AccuracyPerformanceAutomotive
    Its sounds like your clutch. My stage 2 did the same thing. As soon as I put the stage 4 in it went away. We even tore the tranny down and the syncros were fine.
    500whp of spinnin fury!!!
    IS300 NEMO's Avatar
    We Fuckin...
    I have a stage 4 cc
    How many miles are on it? Are they hard miles?
    IS300 NEMO's Avatar
    We Fuckin...
    i put about 300-500 daily driven miles on it before i ran it hard like cc told me to.
    IS300 NEMO's Avatar
    We Fuckin...
    sorry for the cell phone pics but got the transmission pulled last night i took the case off and this is what i found. as i already knew the bear was bad but not this bad. as soon as i remove the case the bear came apart.
    as you can see in the 2nd pic that is the bearing stuck up in the case.
    the 3rd pic is a pic of one of the gears. if someone can make it out are the gear supposed to have the notches on the end of the gears?
    Attached Thumbnails Attached Thumbnails -tranny-jpg   -tranny2-jpg   -tranny3-jpg
    Yes the notches are normal. does that bearing spin? if so its probably fine, they get stuck often, a few taps with a rubber mallet will make it come out, makes it easier to reassemble.
    IS300 NEMO's Avatar
    We Fuckin...
    i will try that when i get back to the house. but i think the bearing was starting to come apart. why would the bearing come off the shaft and be stuck up in the case?
    IA's bass guy
    Nov 2009
    paulding
    need to hurry and get her fixed so you can get that mach1 dude to shut up lol
    99 tahoe, build in progress
    IS300 NEMO's Avatar
    We Fuckin...
    Quote Originally Posted by imprtguy_94 View Post
    very true
    IA's bass guy
    Nov 2009
    paulding
    Quote Originally Posted by NEMO View Post
    very true
    lol believe me im not the only one waiting for it
    IS300 NEMO's Avatar
    We Fuckin...
    oh i know. thats why i need as much help with this tranny as i can get. basically trying to figure out if its a simple fix or if i should buy a new one
    i bet it's synchros. My high mileage hydro was wore out and the cost of parts justified getting a another trans. OE parts started to add up quick and it just needed this that and the other after starting to tear it down for a close inspect....
    your moms house
    it's completely normal for that beraing to do that it becomes stationary when the top half of the case is torqued down.
    check you clutch make sure the springs on the plate are good and check the fingers on the pressure plate to make sure they aren't bent causing the clutch not to release at high rpm that will lock you out everytime
    Quote Originally Posted by all-mota View Post
    x2. Like I said, check ur clutch.
    IS300 NEMO's Avatar
    We Fuckin...
    i will look at the clutch tonight. what do i need to look for?
    Is not a male
    South southside.
