Results 1 to 12 of 12
Thread: HEATING ISSUES
    popping v-tekk
    Boosted 86 pick up!!! :)
    Default HEATING ISSUES
    OK MY 94 CIVIC IS HAVING HEATING ISSUES.... WEN I WARM THE CAR UP, THE TEMP GOES UP BUT ONES IM DRIVING THE CAR OR TURN THE HEATER ON THE TEMP DROPS AND IT WONT GO BACK UP. IT STAY LIKE THAT ALL DAY. IF ANYONE KNOWS SOME THING I WILL APRECIATED THANKS IA
    Check thermostat.
    Senior Member G.C's Avatar
    Forgot
    You should check out the basic stuff out before replacing your thermostat. Probably which you need to replace.
    Check to see if your Radiator Fan is kicking in.
    Check to see if you have enough Coolant in your Radiator.
    Check to see if your radiator has any air in it. Just run the car with the cap open, if you have any air it will burp it out.
    :idb:
    popping v-tekk
    the thermostat is new. but im a try running it with out the cap c if it helps out. thanks guys
    IA OPINIONATOR ilbcnu123's Avatar
    Quote Originally Posted by G.C View Post
    wouldn't all of those problems make the car run hot? The OP's car is running cold.
    you need to make sure all of your coolant lines are clean and corrosion free around the necks were they clamp, that can cause little seperation between the seating surface and mist out coolant day by day driving. and make sure coolant is full and blead of all air when at running temp.
    The H is back... CaTcH22's Avatar
    AccuracyPerformanceAutomotive
    Quote Originally Posted by boost-freak View Post
    x2
    500whp of spinnin fury!!!
    Could have a bad radiator cap, sounds like the system isnt holding pressure. Make sure the thremostat is operating correctly and an oem is best.
    barrow county
    lol run hot ftl.
    its simple fix! cover half the front of the radiator with a pice of cardboard.
    when your driving, the cold air cause the anti-freeze to cool down too much causing no heat from the air vents.
    popping v-tekk
    thanks for all the help.
    Quote Originally Posted by blue_gt View Post
    lol run hot ftl.
    I don't think this is a good idea
    there is a problem somewhere else
    Check you heater valve
    NO ADVERTISING
    Owner/Operator
    Jan 2010
    Cumming, GA
    thermo..check the heater core.
