Results 1 to 13 of 13
Thread: 97 mustang wont idle.
    Stang Mod slostang's Avatar
    Southside
    Default 97 mustang wont idle.
    alright so i just installed a 70mm FRPP throttle body, granetelli upper intake plenum, and a 1/2" plenum spacer. car will crank, get up to about 1500 ish rpm as usual then it just stumbles and dies. feels like a vaccum leak from HELL. only thing i can think of is that when i was putting the EGR valve back on, one of the bolts broke into the new plenum so ive only got one bolt holding on the valve.
    Do you smoke? Light one up and blow smoke around the area you think is leaking.
    Southside
    Quote Originally Posted by Nemesis View Post
    i was actually going to do that tomorrow. as redneck as it sounds. haha
    Ah, that's better.
    No bullshit, it's not the place.
    It has a leak....A smoke machine will work or carb cleaner
    spray break parts cleaner in the areas where the gaskets go. dont use carb cleaner its to flammable an can ignite if done wrong.
    Quote Originally Posted by Barefoot View Post
    I been using carb cleaner longer then you been alive fooll
    Carb cleaner does the same as brake cleaner and it will only burn the amount you spray....For example if you spray .2oz then if it caught on fire its nothing.But if you spray the whole car then your looking for some new skin....
    Also Carb and brake cleaner can do the same damage.....Spray a Dizzy with brake cleaner and carb on a cracked dizzy cap and see what happens...they both burn
    Southside
    it was leaking from the broken bolt on the EGR. couldnt get the bolt out, so i used a shitload of copper RTV and it sealed. thanks.
    Quote Originally Posted by slostang View Post
    Next time leave it to the pro's
    Just sayinnnnn
    Southside
    Quote Originally Posted by ASE*Tech View Post
    Just sayinnnnn
    lol.
    I make 500whp and I drive my shit daily, 3 of the Fords Ive owned have not given me problems. The Nissan/Subaru, etc, have all given me problems but I dont go round talking shit.
    you make 495, not 500 and FERD SUUUUUUUCKSSSSSS!!!!!!!!!!!
    Quote Originally Posted by CH@Dbee View Post
    OH MY BAD LOL 495, NOT 500 LOL
