Results 1 to 23 of 23
Thread: CEL for gas cap
    Newnan
    Default CEL for gas cap
    I've had my car diagnosed at oreilly's and autozone and they said the code showed that my gas cap or some EVAP sensor was bad.
    i dont remember the code, but I had my gas cap tested at the emissions place and it checked out fine.. i'd like to know any other symptoms i could check for.
    thanks.
    stock b16a2 no modifications.
    ps.
    I replaced the PCV valve which was broken and replaced the hose that it connected to. this did not fix the problem.
    learn to english
    Certified Gearhead zspeed24's Avatar
    May not have been screwed in tight old car used to run like dog crap if it wasn't right
    Newnan
    Quote Originally Posted by zspeed24 View Post
    runs fine.. the CEL makes no difference in driving quality nor fuel or oil consumption.
    learn to english
    \m/>_<\m/ dorin48's Avatar
    Canton
    The code reads "Evaporative emission control system leak detected (_____)" It tells you the size of the leak in the parenthesis; large, medium, small, very small. Those can be indicators of where to start looking. Very large or large could mean the cap wasnt on at all or there is an evap hose disconnected/broken. The other sizes point to things like the gas cap having a bad gasket or a cracked or split evap hose. Those hoses run from the top of your gas tank to your charcoal/fuel canister on your firewall.
    if the code was P1457 then it most cases is the cap use a OEM HONDA ONLY no cheap aftershit that will still kick this code!
    ALSO you can NOT go by the emission stations check because your car and cars computer is different then the emissions stations
    Newnan
    I had the emissions station check my gas cap because they have to check the gas cap during the emissions test. The cap tested out..
    learn to english
    Quote Originally Posted by Humphries View Post
    Son I understand this, but like I stated your cars computer is different then the emissions, also who's to say there machine isnt calibrated correctly????
    Smoke test it
    And if your CEL is on for evap I almost guarantee you're running rich whether you know it or not.
    Quote Originally Posted by 81911SC View Post
    Not from a Evap code
    Newnan
    So it is a faulty gas cap?
    learn to english
    It could very be a gas cap!
    Most Honda/acura cars that kick this code P1457 is most of the time the cap...Get a KNOWN good OEM HONDA cap and clear code and tighten it until it clicks, and re try .....let us know what happens
    Newnan
    will do.. i'll go to Nalley honda and get one next week.
    hope i can pass emissions then.
    learn to english
    rolla rollin
    middle GA
    this happened to my buddy on his 05 accord and it was a loose gas cap!
    silly people and their obd2 cars. CEL for everything. lol hope you get it fixed.
    Новак 5speed's Avatar
    Conyers, GA
    My fiances car did that too, and we just bought a new cap and it was solved.
    Amen.
    Newnan
    gas caps not loose.. it's been on for the last 6 months.. just never felt like fixing it until now.. when i have to get the car registered.
    learn to english
    Got a new cap yet??
    Newnan
    will get next week. havent had time..
    learn to english
    Oct 2008
    When it comes to Honda's, there are two main reason for throwing that code. The gas cap is the easiest and cheapest fix, so I would change that out first just to eliminate it. The next time you fill up... listen carefully for the pshhhhhh (purge noise) from the gas tank when you first open the cap. If present, then it was the cap, if not, then it is the bypass solenoid valve under the car next to the gas tank. There are ways of testing this, but it is very involved and would be easier to show instead of described. I use to work at the Acura dealership and 9 times out of 10 ...changing out the solenoid will fix the problem. The thing is....it cost like 250 (not including installation cost).........for this much i could get a chipped p28, dup the map, and turn the ck light off for less....the 2 evap codes apply to the emissions system only and is independent to the car's electronic/fuel sys....it will not have an effect on the car's overall operation
    Newnan
    guess it's the cap, then.. that sound happens all the time.
    learn to english
    North Augusta, SC
    Once the light came on, and after you took gas cap off and back on, did you ever reset it by unplugging the battery? My 3g eclipse had the code because the cap wasn't on tight one time. Was told I had to reset it after I put it on there or the light would stay on. The driving was not effected or anything, once I unhooked the battery and hooked it back up a few minutes later the code never came back on.
    Back to being stock and slow
    Newnan
    done that many times, even had my computer reset at the emissions place.. it came back on about 40-50 miles later.
    learn to english
