HERE IS WHATS GOING ON, THE CAR DOESNT RUN HOT AT ALL, IT JUST GOT NEW WATER PUMP AND TIMING BELT AND RADIATOR FLUSHED AND NEW UPPER AND LOWER HOSES, NEW THERMASTATE, AND A NEW RADIATOR CAP, AND ALL NEW ANTIFREEZE. WELL WHEN THE CAR WORMS UP THE HEAT KICKS IN LIKE IT SHOULD, WITH THE HEAD LIGHTS OFF AND HEAT OFF THE CAR IDEALS FINE, WHEN I HAVE MY HEAD LIGHTS ON AND HEAT TURNED ON AT IDEAL MY RPMS DROP THE LIGHTS DIM AND THE HEAT DONT BLOW OUT SO HARD AND THE HEAT FADES AWAY, WHEN I REV UP EVERYTHING COMES BACK TO LIFE. I CHECKED OUT ALL GROUNDS I DID FIND ONE GROUND WIRE THAT WASNT GROUNDED RIGHT, I GROUNDED IT THEN STILL NOTHING, I WAS TOLD BY A BUDDY OF MINE THAT IT COULD BE THAT I DIDNT GET ALL OF THE AIR OUT OF THE COOLENT SYSTEM, OR THAT IT COULD BE THAT MY ALTERNATOR IS GOT A BAD AMP. IDK PLEASE HELP WITH INFO! THANKS!
hope things work out for you
