Results 1 to 11 of 11
Thread: Cable tranny help
    No go del slo Jdmsol's Avatar
    Nov 2009
    Bremen
    Default Cable tranny help
    I'm new to this and I've googled this and came up with nothing helpful so please no negative comments. I have a ys1 tranny going in a hydro sol, question is how do I make this tranny work in my car I've ordered the conversion kit from innovative. So everything else I need help on. If u have some usefull info or have done one yourself please let me know thanx in advance
    JDM as......
    93 accord cb7
    (traded)
    93 del sol eg1 (traded)
    94 integra dc4 (sold)
    96 db7 ls-t (daily)
    West palm beach
    everything you need is in the kit, what is your question again ?
    NO ADVERTISING
    -IA MANAGEMENT
    Nov 2009
    Bremen
    What else do I need to do any wiring?
    JDM as......
    93 accord cb7
    (traded)
    96 db7 ls-t (daily)
    nope, get a newer style VSS, the rest of the stuff in the kit like the master cylinder adapter and the trans mount will be about all you need, and since its a ys1, it is the bigger splined trans so you can use clutch kits for 94-01 integra's(Minus the throwout bearing of course).
    My line of work
    www.internationaljets.com
    Nov 2009
    Bremen
    K now as far as the vss goes how do I go about hooking a newer one up to it?
    Can I use a d series sensor?
    JDM as......
    93 accord cb7
    (traded)
    96 db7 ls-t (daily)
    West palm beach
    Quote Originally Posted by Jdmsol View Post
    YES
    I found a link for ya...
    http://hondaswap.com/general-tech-ma...es-vss-128865/
    NO ADVERTISING
    -IA MANAGEMENT
    Nov 2009
    Bremen
    Jw cause the length and the splines r exactly the same
    JDM as......
    93 accord cb7
    (traded)
    96 db7 ls-t (daily)
    if you fall get back on 95droppedhatch's Avatar
    in a paint booth
    u can use a d series speed sensor i have a d series on my hydro gsr trans
    West palm beach
    Quote Originally Posted by 95droppedhatch View Post
    Correct.....But you should change the gear on the bottom.
    NO ADVERTISING
    -IA MANAGEMENT
    Nov 2009
    Bremen
    Alright thanks guys
    JDM as......
    93 accord cb7
    (traded)
    96 db7 ls-t (daily)
    Nov 2009
    Bremen
    Did u change the gear
    JDM as......
    93 accord cb7
    (traded)
    96 db7 ls-t (daily)
