Results 1 to 20 of 20
Thread: Runnin on 3 cyl. help
    IA Member SRK420a's Avatar
    Lithonia,Ga
    Default Runnin on 3 cyl. help
    Ok so my car is currently running on 3 cyl. 1996 Eagle Talon. I changed the plugs and wires because i thought it wasn't geting spark but when i cut it on Its still the same i pull the wire of cyl. 1 to see if its getting spark and it is but the cyl is not getting it every other cylinder is pumping fine what could be the problem .....bearing.....piston...blownheadgasket...any help is apreeciated and repped.
    barrow county
    if its not spiting out water than it's not a blown head gasket since the cylinder isn't firing.
    ONE Question...... have you check the injector wiring? on older cars, the injector wire can wear out and break off, so the injector isn't getting signal to let gas into the cylinder.
    bad bearing or piston wont keep the cylinder from firing.
    Lithonia,Ga
    Its rainin so i cant tell wen it stops i will take a better look but so far from the view i had the wire looked fine my friend says i need to do a compresssion check because he says i could have an f'd up piston or ring
    roberta
    also take and switch a injector and see if the problem will switch from that cylinder to the one you put it on if so you know its a bad injector....still nothin then get a comp test and see if its low on that one.then its possibly a bad ring ect
    @ballengine ballistic08's Avatar
    Grayson, Georgia
    definatly do a compression check.
    barrow county
    even with a f'd up ring, it'll still fire
    Lithonia,Ga
    thanks alot guy compression check tomorrow gotta get the stuff from oriellys
    Lithonia,Ga
    Ok so i did a compression test today and cylinder 2,3, and 4 all read about 150, and cylinder 1 reads 0 now what
    Grayson, Georgia
    pull the head and look for a blown headgasket/bent valves, etc.
    Senior Member Patterson's Avatar
    Summerville
    Quote Originally Posted by ballistic08 View Post
    i'm with him.
    Lithonia,Ga
    Could it be a bad piston or ring?
    Yes it can be a bad piston.
    I would look for, burnt or bent valve, melted/broken piston.
    Ring Lands Break all the time is the car boosted
    NO ADVERTISING
    Lithonia,Ga
    Does this help.....when i took the plug back out after test running it the plug had oil on the bottom
    JohnBobAlingAdang 88NaCivic's Avatar
    Walton Cnty
    SRK420a My DSM melted a ex. valve had the same problems your are having..
    Walton Cnty
    here is what it looked like...
    Attached Thumbnails Attached Thumbnails -securedownload-jpg   -burnt-valve-jpg
    Lithonia,Ga
    Quote Originally Posted by 88NaCivic View Post
    dand well im going to being takin my head off maybe tomorrow if it doesnt rain
    Walton Cnty
    o compres. in #1
    Dec 2009
    i've seen a rocker cause this on a dsm, check them when you pull the v/c
    Lithonia,Ga
    I've already checked no problems there
