Results 1 to 34 of 34
Thread: h23 vtec "Blue Top motor"
    Default h23 vtec "Blue Top motor"
    ok heres my story i have a 98 prelude sh with the h22a4 motor well i recently the pulley broke and warped and f'ed up my key way so i figured should i fix the crank with a crank kit or buy a new motor and i did my research on these motors and the seem to be pretty good and more hp an torque so i bought it a h23 vtec "Blue Top motor" any one kno anything about this particular motor
    Duluth, GA
    English first. Punctuation next. Then answers.
    Quote Originally Posted by Captain-Obvious™ View Post
    but for real, i thought that it was just a 2.3 version of the h22, but there is a book at autozone that you can go in and read, it's called "Honda Swaps" and according to them it's a totally different motor, and that some of the parts from the h22 do not fit it, how much truth there is to that, i dont know, believe it cause they seem pretty credible, last time i checked they were going for a bit less than the h22, jhotimports when they were in Augusta had a couple of them, i love that blue valve cover though.
    if i were you i would just go with the jdm h22 and the lsd tranny
    somewhere, GA
    Quote Originally Posted by semitas View Post
    They are a little more expensive due to the fact that there aren't near as many of these as there is the h22a.
    I picked mine up for 1400 cash(normally 15-1600) with a business tax ID from Matt Harrel at Japanese Engine Importers in Doraville. Great place to get a motor from!
    '82 TE72 SR5 Sport Coupe
    3tc
    West palm beach
    I'm not understanding the ?
    NO ADVERTISING
    -IA MANAGEMENT
    Stang Mod slostang's Avatar
    Southside
    just put some gorilla glue on it.
    H23 vtec is an obd2 motor out of a accord sir wagon iirc
    what else do you want to know
    AccuracyPerformanceAutomotive
    Like the type-r of the h series
    500whp of spinnin fury!!!
    there is a h22a7 that came in the accord type-R in europe that puts out more power than the h23a vtec
    About to approach beast mode
    i just noticed this is your first post, welcome
    I will buy you're fuked up motor!
    Respect my Authority SilverSurfer's Avatar
    The Barracks
    H23A VTEC
    Accord Sir Wagon (CH9) (JDM)
    197hp@6800/163tq@5300
    notes: 10.6:1 CR, open deck likely regular JDM H22a head. 95mm stroke
    1. 55mm mains
    2. no squiters
    3. counterweights similar the h22a4
    4. p13 head
    5. open deck
    6. high compression
    7. and it has a auto tensioner on the timing belt
    Center to Center of Rod is "CLOSE" to 5 9/16
    * H23A (3 generation, SiR) DOHC 16-valve inline 4-cylinder VTEC 2258cc (× bore stroke: 87.0 × 95.0)
    147kW(200PS)/6,800rpm 221N・m(22.5kg・m)/5,300rpm:FF 147kW (200PS) / 6800rpm 221N m (22.5kg m) / 5300rpm: FF
    140kW(190PS)/6,800rpm 221N・m(22.5kg・m)/5,300rpm:4WD 140kW (190PS) / 6800rpm 221N m (22.5kg m) / 5300rpm: 4WD
    google ftw!
    somewhere, GA
    What you need to know? I had one in my hatch and its a beast.
    Same head and block castings as the h22 were used....it has a longer stroke and flat top pistons(as opposed to the "dome" of the h22a) thats where it gets that extra .1 of a liter. Its a great motor, just don't rev the piss outta it b/c its powerband and bottom end were designed for the auto AWD tranny. If you decide you want 8k rpms all day, then stick with the h22a
    Pretty much all the specs have been stated and yes, google is your bestest friend!!!
    3tc
    if you want to rev to 8K, trade it with me. i got a JDM H22A for ya!
    na the swap is almost complete im waiting on a pulley from honda they had to order then everything is goin in... everything is new new seals all around clutch kit. im selling the old motor for 500 it will crank and run no knocking or anything just the end of the crank is sheered bad.. all they had to swap was the oil pump the housing around that sumthin about the oil pan they had to swap im not sure wat it was intake plenum headers an thats it it dont have an egr valve and the oil pump housing an pump was swapped to add the crank angle sensor but i should have it monday night so i will let everyone kno how it runs? if it has any more than the h22a it will be a beast in the prelude
    somewhere, GA
    LMK if you need sensors or plugs...i have a whole h23vtec engine harness in my garage..
    did you switch everything out to OBD1?
    3tc
    nope they used everything off my old h22a motor to put on the old one so it will still be obd2
    and say if a prelude with a h22a4 motor an mine with the blue top raced which one would win?
    somewhere, GA
    blue top...torque is the winner.
    if you need any sensors or plugs LMK...there is a pic of the harness in the link in my sig
    3tc
    how do u think it would do against a stock mustang gt cuz they blew my h22 away no prob
    ok wat about a mustang gt an the blue top cuz they smoked my h22a all day long
    somewhere, GA
    i dunno...thats just b/c the lude is heavy
    in the hatch i ate up GT's all day long...
    3tc
    o well i will be happy if i tell any diff at all lol i might put some cams an i got a port an polished head im building on to
    somewhere, GA
    It is a whole diff powerband...you will def. notice
    3tc
    what gear is gonna be my strongest an wats the safe rpm range ?
    somewhere, GA
    get it tuned before you do anything...
    second gear is a beast and 4th on the hwy dessimates
    dont rev past 7500....
    3tc
    well itll have to be summer before i get it tuned cuz money an work is slow but im not gonna be racing or reving it high anyways because i need a reliable car and dont have the money to pay if something breaks because of racing
    somewhere, GA
    yeah be easy with it till the tune...shift a 3k all day till then
    3tc
    lol cant i just see what shes got once or twice lol
    hmm interesting, ive heard of the h23 vtec but never actualy seen 1 in person. or maybe i have just never noticed lol.
    GL with the motor man
    damn, i want that penis
    somewhere, GA
    I posted pics of mine in the hatch...someone on the boards has it now
    3tc
    Dec 2009
    ATLANTA, GA
    kind of new here. does anyone know a good place where i can get my H22a swaped? ive got a 98 prelude. Prefer something under a 1k for hands.
    somewhere, GA
    Quote Originally Posted by BB6Luder View Post
    sponsor section...mainstream performance
    3tc
