Quote Originally Posted by k3tsurui View Post
module is different for sure, but why would it work sometimes and not at other times is what beats me. but the reason that i am using it is because i have type r door panels and didnt want to rewire the harness for the civic module (which i would need to buy in the first place) i just figure the problem is like a relay timing issue or the way that the door lock is placed....i havent noticed any patterns but sometimes when i close the door in an abnormal way, then my locks would work, btfoom
there is no relay timing or delay for locks, it's simply a relay. It's possible one of the relays has a bad connection, or whatever you're using for an output signal is weak or bad...hence it's inconsistency. If you already have harness, why not just manually wire up two relays and call it a day?
