Results 1 to 10 of 10
Thread: integra/check engine light question
    Certified Gearhead nstygomez's Avatar
    Jul 2009
    marietta
    Default integra/check engine light question
    Well I was on the freeway last night on my way to moreland and wen I hit 75-80 mph my check engine light came on and started blinking so I slowed down and wen my speed dropped the light went off. The same thing happened twice. Anybody had somethin similar happen or the same thing happened to??
    when the check engine light blinks it usually means the engine is misfiring. anything else happen? was the car shuddering/stuttering? did the CEL stay on after (you could pull the code and get more info)?
    check the coil, plugs, wires, etc to make sure everything looks good. someone who knows more about cars than me will drop in soon with some more suggestions
    Quote Originally Posted by trini_gsr View Post
    x2 for the noob
    Jul 2009
    marietta
    No the cel light turned off after I slowed down a little bit. And no that was about all that happened.but my cel light has came on b4 and wen I checked it it said that one of my cylinders was misfirin but that was only bcuz 1 of my spark plug wires had came loose from the dizzy
    well i guess when you're getting on it, something is causing the motor to misfire. do you have an OEM ignition (no msd external coil, etc)? when's the last time you changed your plugs and wires?
    like i said i'm no expert but this is the stuff to check out in this situation...start with the easy stuff and work backwards till you figure it out
    Jul 2009
    marietta
    Yea I believe the ignition is oem. And the last time was like in september, I was gonna do a oil change and change wires and plugs this weekend
    West palm beach
    speed sensor going bad maybe....
    NO ADVERTISING
    -IA MANAGEMENT
    the duckster
    Rome
    if its a da, fuck our speed sensor
    mine has been bad for i dont know how long
    Race Ready Developments Member #5
    Rome Crew
    SHUT THE FUCK UP.COM bonezMTA's Avatar
    Jun 2009
    Marietta, GA
    fuck the check engine light. you know half the people ride with it on.
    Have you heard of the guy who rolls and pulls fenders in Atlanta? YEAH, I'M THAT GUY! Hit me up! https://www.facebook.com/VipFenderRolling
    YR88 Win! Romeo's Avatar
    Middle Ga.
    Quote Originally Posted by ducky1177 View Post
    Yours speedo is cable, ding dong.
