Results 1 to 5 of 5
Thread: Oxygen Sensor Help
    Projects
    Default Oxygen Sensor Help
    I bought a 96 civic with no exhaust just the header and i need to know where does the lower o2 sensor plug into at ? A picture of it or a diagram would be great +rep for help thanks
    Projects
    i need this info asap please help honda peps
    1990 mazda rx7 TII
    Oct 2008
    brookhaven
    rtfm
    if the cat is under the car (behind the exhaust manifold) it will have a plug that comes out around the shift linkage. If the cat is on the manifold (on the front of the engine) it will have a plug around the tranny area. Sorry I don't have pics. It should be pretty easy to locate
    Oct 2008
    Quote Originally Posted by TommyD1919 View Post
    x2 ....its near where you oil filter is go under the car into that area with a flashlight - - also if they removed that cat then they probably tucked the connector away but it should be like 5 inches from where your oil filter is if it is in the factory location
