Results 1 to 21 of 21
Thread: 1 wire O2??
    Senior Member DustnU's Avatar
    I'm on a boat!!
    Default 1 wire O2??
    Will running a 1 wire O2 when it's supposed to be a 4 wire cause vtec not to work, and will it also cause car to run extra rich????? Any answers???
    Work in progressneed slicks!
    somewhere, GA
    ummmm....4 wire should be replaced with 4 wire...3 with 3...and so on...
    '82 TE72 SR5 Sport Coupe
    3tc
    Newbie Photodude RBS's Avatar
    All Over U S A
    vtec will not work without an 02, on a stock ecu that is.
    i dont know how your running a 1 wire, but you should grab a 4 wire and wire it up. its a measly 3 wires
    Quote Originally Posted by DustnU View Post
    O2 sensor has nothing to do with vtec
    I have ran without O2 sensors all the time with Vtec working just fine
    somewhere, GA
    Quote Originally Posted by Tech5 View Post
    Chrome gold...hondata...etc.
    O2 delete
    3tc
    it will throw code for o2 heater and poss o2. it may or may not engage vtec. get the correct o2 or have it disabled via chipped ecu.
    let me know if i can help.
    I'm on a boat!!
    Ok the car is a cx but has a vx block with y8 head and a virgin p28, thats why it has a 1 wire. I have a 4 wire to install, i just wanna know if thats one of the reasons it's running rich/sputtering alil and when vtec engages it boggs. I need pins for the ecu to run the O2wires i have the wrong ones I think. thanks for all the info guys greatly appreciated!!
    tune up?
    loose dizzy
    fuel line is damaged
    water in dizzy
    timing
    I'm on a boat!!
    ^^^^ You the man thanks!!
    Projects
    it will run rich and like shit with no o2 and with only that 1 wire i doubt it will even read its there. I am having this issue right now with no 4 wire o2 and mine runs shitty and rich.
    Just do a 4 wire o2 its the best bet
    I'm on a boat!!
    ^^^^thank you sir that pretty much sums it up.
    Quote Originally Posted by JDMJAY View Post
    I have worked on so many swapped cars with no o2 sensor or un hooked ran like a champ no issues ... Yes runs alittle rich but doesnt make it run like crap
    Projects
    i dont know why it does i mean ive had other cars that wasnt honda and no or bad o2 will make them run like crap and have bad idle. also drank gas hella fast
    I have worked on many car makers with O2 sensor codes, CEL and never had one cause it to run bad. Maybe if the tune up was shitty I could see that issue.
    But never a O2 sensor making it run like shitt. But yes making it use gas Oh yeah
    Projects
    someone told me they is a dumby o2 you can use to fool the ecu is that true ?
    Cause im getting a full catback from the header-back and it has no o2 port but my car needs one
    I'm on a boat!!
    well wouldn't dumping fuel cause it to sputter if its too much??? has very low compression vx pistons are concave as HELL!!
    No not on a stock regulator and pump
    Ford sales a MIL that hooks between the O2 plug and cars factory plug that tricks the ecu.. But not Honda...You will have to buy and chip it to delete it
    I'm on a boat!!
    I'll just wire in the 4 wire and be done with it, if it still sputters i'll look into bent valves or low comp in the cylinders. thanks
    best of luck
