Results 41 to 46 of 46
Thread: clutch question, input needed.
  1. #41
    Warner robins ,Ga
    just get a twin or triple disc. fuck all the bullshit.
  2. #42
    Warner robins ,Ga
    Quote Originally Posted by slostang View Post
    i had the same setup in my ef. it was fine till you got to sit in some traffic. then it was cable clutch + 2200lb pressure plate = in traffic.
    you need to hit the gym and do some legs workout then.
  3. #43
    Stang Mod slostang's Avatar
    Southside
  4. #44
    L'ville
    psh, pedal effort is nothing compared to whatever i had in my DC4. i absolutely hate soft clutch pedals
  5. #45
    JJSPEC Racing
    Quote Originally Posted by FlipKing View Post
    Maybe I'm wrong, but I've always heard that like was mention before, the lighter flywheel will bog off the line in a launch, while the heavier flywheel snatches harder.
    maybe you are wrong...
    -2001 Lexus IS300
  6. #46
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    stock will keep you from falling out of vtec if on stock ecu because if too light a flywheel is used it will return to idle quicker so between gears it will fall out of vtec. noe if boosted i still run a stock gsr flywheel wich is a few pounds lighter than the thick ls and an xtd will slip with boost but is ok na . i had to go with a clutch masters fx500. is 6 puk unsprung dd.they have less pedal pressure and feel great with no required break in. had mine for 6 years no probs and has been through 3 trannys.
