Hi guys im from the US and I have a couple simple questions.
First...
I have a 92 sc300(US Soarer) with a 95 1JZ in it that I am trying to finish....
The alternator that came with it obviously had the alternator plug coming from the chasis... As my car is a 92 the alternator plug came off the engine wiring harness. So that said...
I do have a 95 alternator plug and wires. It has been extended into the cabin where the engine harness meets the ECU.... Which wires do these go to? I know that I can simply color match but the wire coloring change from year to year. Any help would be awesome...
Which plugs are the wires located on? Can I simply just cut some plugs and rewire?
Second...
I have a few plugs that aren't matching up. I need to know which wires will go to what....
The body plug -
The Engine Harness -
Ill be pretty much be swapping out the connectors for GM connectors.
But which wire goes to what though? I can pretty much figure...
Plug 1 Plug 2
Red Black ------Red Black
Gray ------------Gray
Blue 1 ?? Small White ??
Blue 2 ??
Three....
Can anyone point me out in the direction in which were the grounding points are for the 1JZ/2jz?
Thanks.
