Results 1 to 11 of 11
Thread: Plasti-guage question.
    \m/>_<\m/ dorin48's Avatar
    Canton
    Default Plasti-guage question.
    I know I could look this up but i felt like giving our experts a chance to show off.
    I understand what and why but not how.
    Whats the technique for using plasti-guage?
    Newbie Photodude RBS's Avatar
    All Over U S A
    place it between the crank and bearing, torque down, carefully remove and then measure... pretty simple
    Canton
    Makes sense. I knew it would be simple but just wasn't sure.
    All Over U S A
    Werd
    ia "racist" dallasb84's Avatar
    Jul 2009
    it will also come with a little chart thing that you compare the smash width for the clearance....... doesnt usually come with the plastiguage i dont believe but i used to have one before i lent it out....
    Mountain man green91's Avatar
    Dahlonega, Ga
    Quote Originally Posted by dallasb84 View Post
    The plastigauge comes in the package thats used for the gauge, it always come with it.
    For most import motors you will need the GREEN plastiguage.
    IA Sponsor JJSPEC Racing's Avatar
    www.jjspec.com Macon, Ga
    Make sure you clean the oil off of both surfaces and dont let the crank rotate any. Both of these will affect the reading. And correct on the package having the chart on it. You probably want to use the green plastigage for crank and rod stuff.
    JJSPEC RACING - Central Ga's source for performance parts,
    fabrication, tuning, general repair and a whole lot more! 478 621 5000
    Bender A. Rodriguez
    Macon
    I won't use it anymore. Its too easy to get a false reading if anything moves or the cap rocks coming off. I use a ball micrometer and a dial caliper to verify clearances. Its more expensive to go that route so if you're only building one engine its probably not worth it but for me and as anal as I am about stuff like that it was worth it.
    Ryan Reynolds
    "So long and thanks for all the fish"
    Privateer Racing!!
    Duluth,Ga
    We have never plasti gauge a motor and they all have been fine. We use standard bearing and roll with it...
    Quote Originally Posted by Cool Cat Racing View Post
    This is definately the best way. Just answering the op's questions about the Plastigage.
    Quote Originally Posted by B18c1Turboed View Post
    LoL
