Results 1 to 11 of 11
Thread: air problem
    Senior Member EJdm's Avatar
    Default air problem
    89 crx...car isnt blowing any heat its just dead...what do i need??? and how much will it be for the part??? thanks
    Sep 2009
    Cullman Alabama
    could be a bad relay, fuse, wiring, any number of things. maybe even a bad blower motor.
    ap2 lbp s2k
    Hampton
    is it blowing air at all, just anything besides heat?
    the county
    pretty much what the other guys said. is it blowing at all? or just not the heat?
    Newbie Photodude RBS's Avatar
    All Over U S A
    bad heater core, or the heater hose/heater switcher is clogged.... and thats IF your blower fan works
    well its was blowing air but now nothing...my friend said something about a blower but i just want to double check...
    Quote Originally Posted by EJdm View Post
    Quote Originally Posted by 94@ccordLX View Post
    fuse is okay...where can i check for relay??? i should just take it to the shop...im to lazy now and days to mess with cars...
    check all items before the motor and grounds.
    thanks...
    Loves Twinkies Schroeder's Avatar
    Oct 2009
    In the Garage
    Put a test light on it at the blower motor with the fan switch on, if the light turns on, you have power therefore its a blower motor. If you dont have power its a fuse, possible relay if the sys has one, or just a general wiring problem i.e. no ground or pwr wire broke. Do you have power to the heater control panel?
