Results 1 to 15 of 15
Thread: B series in eg questions.......?????
    revolution big mac's Avatar
    Default B series in eg questions.......?????
    Okay here's the deal. I had a built boosted ls vtec in my old ej8. I'm going to swap that I'm to my eg now. I know I'm going to need mounts and intercooler piping for the eg. My questions are will the axles of the ej8 work on the eg chasis? Will the shift linkage or the ej8 work on eg? Any help or tips to help me with me questions will be repped!
    Aug 2009
    yes the axels and shift linkage will work. i think the piping may also work but not sure about that part
    Okay thank you man just wanted to male sure before I ordered parts. Hahah. I think I may have to work with the piping to make it fit snugly behide the bumper
    Repped
    roberta
    yep it works....
    rolla rollin
    middle GA
    evrything will bolt up perfect and is you motor obd1 or 2 cause you may need a jumper harness depending on what ecu you run!
    Quote Originally Posted by jcs View Post
    yep it works....
    I'm using the same ecu and harness from my last car. P72 with obd2 to obd1 jumper harness. It maybe the other way around I forgot lol
    rolla rollin
    middle GA
    Quote Originally Posted by big mac View Post
    lol alright just making sure lol didnt want you to do all that work mto get nothing out the ecu
    Lol that would suck but thanks bro.
    Super H8ter Starrfire's Avatar
    well now you don't have to step down to obd1 since the car will already be obd1.
    Axles and shift linkage work the same, no problems there. Just finding mounts and a rear L bracket.
    My line of work
    www.internationaljets.com
    you cant use your old engine harness because its obd2.
    its 1 piece straight to the ecu, where obd1 plug up at the shock tower
    GOONie blue_lude_91's Avatar
    Ft. Worth, TX
    all things work and youre lucky cause your eg is an obd1 car!
    slingshot sales ceo. ls-r teg's Avatar
    gwinnett
    sell the jumper harness engine harness and get wire it up for obd1
    STILLHAVE THAT PENIS ?????
    They should have never gave u niggggas vtec
    the county
    in most cases the eg and ej are the same body styles. 92-95. from everything i've done, just about all the parts will swap out.
    Mine old one was a 99 though
