Results 1 to 12 of 12
Thread: best solution to....
    the county
    Quote Originally Posted by Purple Power View Post
    slace? .. slave cylinder? clutch?
    eh, take a small 1 foot hose and stick it on the nipple on the slave cyl. and open the nipple up a lil, and stick the other end in a cup full of brake fluid, making sure that the end stays submerged. and then, just pump away until you feel like it has straight clean fluid in it then close the nipple.
    ive been doing this method for years and it works perfect everytime, no need for buggin a friend or a expensive shop tool ( although it would help )
    yes the slave cylinder for the clutch. that was a type-o on my part.
    Quote Originally Posted by Barefoot View Post
    http://www.amazon.com/gp/product/B000JFN9WC thats what im talking about. does the job in a 5 mins for all 4 wheel.
    its not for the brakes. the brake lines look pretty clean. nothing in the fluid or anything. just the reservoir for the slave cylinder. but i will have to look into getting that and see how it works.
    Quote Originally Posted by Master Shake View Post
    it will work for clutch lines also. by no means is it the cheapest route but it is the fastest. an in a shop environment pays for it self in time saved.
    the county
    word. thanks for the info!
    Pick up a Motive brake bleeder if you are going to flush/fill/bleed the brakes reguarly. You piur the brake fluid into the Motive container, hook it to the master cylinder, pressurize it with the hand pump and open the bleed screw. Done flushing in no time flat with no air in the lines.
    http://store.motiveproducts.com/shar...unt2=829475045
    One of the best tools I've ever owned to make a tedious job simple.
    Feff
