Results 1 to 40 of 64
Thread: Ride height issue after new springs
    polar bears toenails
    Kicking rocks
    Default Ride height issue after new springs
    Ok just had tein s techs installed on my Lexus is 300.
    (springs have been on the car for well over a month)
    The left rear is sitting half an inch higher than the right rear. Looks like everything was done right. The right rear looks to be exactly the way the s tech drop should look but the left is all jacked up. Wtf??? does anyone know what this could be? Blown strut???But wouldnt that make the car lower than higher?
    See the height difference?????
    Quote Originally Posted by KREEP View Post
    The left rear is sitting half an inch higher than the right rear. Looks like everything was done right. The right rear looks to be exactly the way the s tech drop should look but the left is all jacked up. Wtf??? does anyone know what this could be? The shop is saying blown strut but wouldnt that make the car lower than higher?
    got a pic
    Kicking rocks
    got a pic
    No pics... you really can tell if you are looking at the rear of the car and if you are on the driver side. tape measure shows a half inch difference
    na i mean of the setup installed not of the whole car.
    like this
    Attached Thumbnails Attached Thumbnails -rearcoilover-jpg
    Kicking rocks
    like this
    no but I can get some in the morning. I will be jacking it up and taking a look.
    np
    Kicking rocks
    someone said this on my.is forum
    (it might not be settled yet. also, if they torqued the suspension mounts while it was in the air, then the bushings could be torquing the suspension on that side. If I were you, I'd loosen the lower shock mounts, put a jack under the control arm to lift it up, then retorque. If that doesn't fix it, then it might have been installed wrong (people make mistakes ... some people just don't care) so if that's the case, I'd take it back to the shop and ask them what's up.)
    Does this sound right????
    ALL CAPS JITB's Avatar
    im sure it is, but are the springs on the right place. the rears in the rear, and the front in the front?
    Kicking rocks
    Quote Originally Posted by JITB View Post
    shit...I hope so Lol. I am jacking it up in the morning and checking it out.
    rolla rollin
    middle GA
    damn never heard of that problem! try the torquring thing and see if that fixs it
    iTouge HillClimbGuy's Avatar
    snellville
    it has to settle first have the driven the car at all yet?
    letting your supension settle is very important i have seen many cases where poeple install coilovers or springs and shocks and do not break in/settle the springs and the next day they crash because of it being unstable. just drive it normal for a day or to and see if it evens out then.
    Ballerness is like butter you just can't blob it in one place you got to spread that shit around
    Kicking rocks
    Quote Originally Posted by HillClimbGuy View Post
    Its been more than a month or two.
    somewhere, GA
    u sure they didnt send u the wrong spring???
    like a stiffer one accidentally got put in with your set? It does happen
    '82 TE72 SR5 Sport Coupe
    3tc
    Kicking rocks
    Quote Originally Posted by D3UC3S View Post
    I will be double checking but I am pretty sure that they are correct.:boobies:
    Kicking rocks
    anyone a mechanic that could help me out???? That is close to Athens or jefferson/jackson county
    JDM TYTE AnthonyF's Avatar
    Cumming
    A mechanic isn't going to be able to fix a broken or incorrect part. Did you check to see if the springs were the same? Where are the pics? I would call up tein and ask them. That's the smartest thing to do.
    -Ant.
    The Carbon Fibered R6
    Kicking rocks
    Quote Originally Posted by AnthonyF View Post
    -Ant.
    Would they just send 1 wrong spring? And how could i tell if the 1 is wrong?
    this should answer your question
    Whos got the best deal on Enkei Wheels?
    somewhere, GA
    its happened before...
    3tc
    Kicking rocks
    Default hmmmm
    -Ant.
    The spring isnt broken....it could be incorrect or installed wrong. I also know or heard that when installing the springs on an is300 they cut the bumpstops. Would that have anything to do with the ride height?
    Has it been like this since they were installed? Or is this recent?
    I've seen this before with cars that had a different rate spring on accident on one side. They don't say rates on them do they?
    Kicking rocks
    How could I tell ? I will look on the springs. Call me I texted you earlier to see if Jesse could look at it for me
    I got a new phone I will text you.
    Shows the spring rates, if it has them, check them. I am sure they didn't install the fronts on the back or anything you'd know VERY easily.
    Kicking rocks
    Ok im going to jack it up take the wheels off and take pics.
    Kicking rocks
    Ok pics are up Look at the side view pics of the gap between the tire and the wheel well. The gap difference is half an inch. The lower side looks to be the right height for the Tein s tech drop. The other side look jacked up!?!?!
    Yeah, like Jesse said I think the higher side is the side that's messed up. I don't see anything wrong from the pics how the springs are sitting. You have all the same size tires right? lol.
    Do you know which pic of what side is what? Like which pic of the spring is right and left?
    Sep 2009
    NW GA
    You can tell by the position of the calipers.
    Sep 2009
    NW GA
    Pass.
    Driver
    ^Good point haha.
    Is the top of the spring on the driver side sitting right?
    Sep 2009
    NW GA
    Can't tell from the pics, but do both springs have the same thing written on them? If not then that could be the problem.
    Kicking rocks
    LOL Tires are all the same.......Would the bumpstops being cut make any difference in ride height?. I just think something wasnt done right.
    Sep 2009
    NW GA
    Possibly depending on if the pass. side is making contact and limiting it from going up any further.
    Kicking rocks
    yeah I am no mechanic so I have no Idea if the bumpstops have anything to do with ride height.
    Hiawassee, GA
    If when they cut the bumpstops down they left one taller than the other the car could be resting on the bumpstop causing it to sit higher on that corner.
    Threadjack:
    When are we playing SOCOM negro?
    -Zach-
    1987 Toyota Pickup - Toy
    Senior Member G.C's Avatar
    Forgot
    Easiest way, Switch springs. See if the problem goes to the other side, if so you found your problem.
    If not, You know something is wrong on that side. Start from there, guessing doesn't help.
    :idb:
    Sep 2009
    NW GA
    if it's sitting on the bumpstop then it would be a pretty harsh ride. You would know from driving it if it was the bumpstop or not.
    Yeah I doubt it's riding on the bump stops.
    The swapping springs isn't a bad idea if it's at Jesse's shop taken apart anyway.
    Kicking rocks
    Yeah II just took the bottom bolt loose and jacked it up and I am letting it sit there for a few minutes . Then tighten the bolt and if that doesnt work to Jesses I go
    snellville
    This may sound weird but could you get a side shot it looks like you may have an camber issues. Did you get it alinged after the spring install, camber can make one side look lower or higher.
