Results 1 to 13 of 13
Thread: broken wheel stud on a civic?
    Newbie Photodude RBS's Avatar
    All Over U S A
    Default broken wheel stud on a civic?
    my wheel studs are f'ked due to the previous owner of the car going to a cheap tire shop.... and now im in a battle trying to replace these things.
    its a 93 honda civic ex NON abs. and im having a very hard time getting the stud back in... ive tried the trimming method and the stud is still almost at a 90 degree angle.
    so are there any other tricks? is it safe to pull the hub apart?.. even though im trying to avoid that
    help would be greatly appreciated
    Certified Gearhead Big Deezy's Avatar
    In da kuntree
    you can pull the hub apart... Not worries on that... but the best way to get them to pull all the way through is to get you open end lugs, crappy ones that you care nothing about and tighten them on... It will pull the stud through as you tighten. That's how I've always done mine... Works like a charm.
    P.S. it helps to have an impact gun when doing that method
    Quote Originally Posted by Big Deezy View Post
    not sure if that the step he is talking about.
    http://www.youtube.com/watch?v=JAcMwPCI6a0
    Aug 2009
    i had to do this to one of my car once.. it will work better if you got a WASHER between the hub and lug. try it!!
    vanilla sky.
    neat trick/
    your doing oem studs sizes not extended correct.
    All Over U S A
    Quote Originally Posted by Barefoot View Post
    i tried that method already, for some reason my hub is fairly too large and even after trimming the new stud its hard to go because of its angle... hell taking out the old one was hard... i literally had to cut BOTH ends of the old stud to remove it
    yeah, all oem sizes
    Quote Originally Posted by Purple Power View Post
    yeah, all oem sizes
    ive done it this way countless times. u sure your trying to install on the right side of the hub without the backing plate.
    to get them out u just brake them off.
    General Tech Hater
    yeah post some pics of your situation..
    Official "Delete the clubs/crew section of IA" Member #1
    Quote Originally Posted by chouston86 View Post
    So this is how it goes down when I beat you I want the cash and the respect. To some people thats more important. Sounds familiar?
    All Over U S A
    Quote Originally Posted by MidLifeCrisis View Post
    will do. be up in a lil bit
    West palm beach
    I removed my hubs and beat them out, then installed the new ones. No cutting/grinding ect. very simple process....
    here is a link, http://www.c-speedracing.com/howto/w...ds_install.php
    Quote Originally Posted by punkr6 View Post
    i just press them out cut the left over race if any. replace the bearings. lefts face facts these are over 10-20 year old cars now. new bearings should be on the list.
    West palm beach
    X2, if your pulling the hubs, go ahead and replace the bearings.
