Thread: CEL 9 and 20
    San jose, CA
    Default CEL 9 and 20
    so i swapped over my b20 into my 90 civic hatch. Now im getting CEL numbers 9 and 20. The car was previously in my 88 hatch and it had no CEL at all. The car has been converted to OBDI. any ideas o fixing these problems?
    9 You need to check your dizzy or the wiring for it.
    9 cyp
    20 eld
    how was the obd1 conversion done? did you use a boomslang conversion harness or did you try and re-wire everything yourself?
    9-try dizzy
    20-try alternator
    i could chip the ecu and disable the eld issue, but you need to fix the cyp.
    HONDATA DEALER/TUNER
    NISSAN REALTIME-NISTUNE
    San jose, CA
    Thanks for talks help guys! I got rid of the 20 it was the alternator. As for the 9 the conversion was done with a harness. I don't know what I should be looking for as the wiring goes. The wires that plug into the ecu look like there getting loose though not sure if that's the problem
    San jose, CA
    ill be doing b20 vtec also hopefully soon
    San jose, CA
    i cant find the solution to code 9
    Quote Originally Posted by Brut View Post
    what have u done so far to diag. it.
