Results 1 to 14 of 14
Thread: New AC system installation on 93 civic question
    Senior Member Schugg's Avatar
    Default New AC system installation on 93 civic question
    i was looking to buy a new ac compressor after a bad experience with a remanufactured one i bought, probably from some bootleg company. but i couldnt find any new so now im just buying a orielly remanufactured one and trying that out. along with replacing the ac compressor, im replacing the condenser, and accumulator. im thinking of replacing the expansion valve but i have heard its a pain in the ass, i dont know if its bad or how to know if its bad, should i go ahead and do that since im doing all the other things or is it unlikely to have anything wrong with it. the car never had good ac, cause i bought it with a bad compressor, replaced that with a bad remanufactured one, and since then its been riding around with no ac parts in the engine bay. car has at least 325,000 miles and its a 93 civic VX. is there any other ac parts i should think about replacing?
    - 1993 Honda Civic VX
    - 2008 Acura TL-S
    JDM TYTE AnthonyF's Avatar
    Cumming
    Explain bad compressor? If the lines were leaking or leaking behind the pulley, you don't REALLY need to replace all of those items. Your AC will be much colder if you replace all of those though. If your compressor was making a ton of noise, then yes, you should replace all of those items BUT make sure you clean out the lines of any unwanted debry. If you don't, that trash can get back into the compressor and destroy it and you have to start alll over.
    -Ant.
    The Carbon Fibered R6
    -Ant.
    dat right
    wrong, a compressor with that many miles I suggest replacing all. If not all the trash and metal will get into your new parts and damage them!!!
    I would replace all, the expansion valve is super easy takes me 15 mins..... not hard at all and will make a world of a difference and last a long time. BTW most companys will NOT warranty anything if you don't replace them all...Condensors can be cleaned out and reused and the evaporator also as long they are not leaking and the fines are in great shape....
    I am a ASE certifed A/C Tech also
    -Ant.
    the original compressor it had when i bought the car, the guy said it ust needed recharged, but after i got the car home, i seen the compressor had a hole on the backside of it. so i called that one bad, bought the random companies remanufactured compressors, charged everything up at a shop and it wouldnt get cold, just started off cool and got hotter. went back to the shop and told them that it was a remanufacture and they said if it wasnt a good company they probably didnt replace all the seals and what not. so i was just like whatever, went home took it apart and it looked like shit inside so just assumed it was never reman'd and trashed it.
    how would i clean out the lines?
    - 2008 Acura TL-S
    replacing all parts i named, or all parts as in those things, and other things i didnt list, and probably dont know about? what is a good way for cleaning the condenser? i can do that now since its still sitting in my garage.
    - 2008 Acura TL-S
    Reason it didnt get cold is your head presure was way to high....
    The hint for the old compressor having a hole in the back is because it blew the valve out,,,
    need to replace
    compressor,expan valve,dryer
    clean the lines with brake cleaner and compressed shop air,clean until all the black crap is out of the lines, clean the condenssor,evaporator also and the other lines if you can.... best of luck....
    make sure you get the presure correct on the low side and high,.,,. 2 -12 oz cans feron tops
    Cumming
    Currently Active Users Viewing This Thread: 3 (3 members and 0 guests)
    AnthonyF, Tech5, Barefoot
    3 most important people on this site are in here helping you. You can't go wrong with that.
    -Ant.
    need to replace
    thanks again! do i clean condenser and and evaporator the same way as the lines? also i don't remember if i asked before, but do all the lines have to be removed or disconnected anywhere to clean them? as for the evaporator is this the part up under the dash that looks like a mini condenser inside the plastic box. sorry for all the questions, just want to get it right this time! as for charging it i had a shop on base do that with their machine, didnt bother with the cans.
    -Ant.
    haha, thanks for letting me know that
    - 2008 Acura TL-S
    No you dont have to take all the lines off to clean, mainly just the condensor which is next to the radiator and the evaporator which is under the dash and also to clean take the battery out and the tray and the mount bracket and you will see where the lines go into the evap . Take those lines lose and remove and clean the same way as i stated into each of those items until no more black nasty stuff lol...
    hope this helps for faster reply PM me thanks Joshua
    Cumming
    ^cus it SHO ain't phone calls.
    -Ant.
    ^^^^ AASSSSS
    im co signing i missed most of the convo but nothing was a lie.
    now why would I lie lol
