Results 1 to 14 of 14
Thread: clutch question
    Gwinnett-Grayson
    Default clutch question
    alright, so on my teg, lately there has been this weird noise i can hear every time i push down on the clutch, like it squeaks like its not lubed up enough or soemthing, and i am at a los of what to do, i dont want to take it to someone and have to pay them a shit load if its something i can fix myself, anyone know why the hell it might be squeaking the way it is ?
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    Gwinnett-Grayson
    someone fucking help me out!!!!!!!!!
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    Formerly Spyder Man
    Buford, Ga
    so when you push it down it squeeks? sounds like it could be one of a few things, throw out bearing being one.. springs in the clutch assembly being the other. either way you have to drop the tranny to see what it is. if you are taking it that far you need to likely replace the clutch/pressure plate/throw out bearing all at the same time.
    :boobies:
    Jul 2003
    Atlanta Centennial Park
    Quote Originally Posted by Spyder Man
    +1 vote
    -www.usedbarcode.net
    Gwinnett-Grayson
    are you seriousl i have to do all of that just for the fucking thing squeeking when i push down on it?!!!
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    dude, does it squeak as you press it...
    does it squeak when its depressed?
    Formerly Spyder Man
    Buford, Ga
    Quote Originally Posted by blacknightteg
    no. you dont have to do shit, you can keep drving it until something worse happens. like the throw out bearing failing (exploding, melting, etc) or a spring falling out of the clutch assembly. either way everything is fine then one day you no longer have a clutch... well atleast not one that will disengage.
    :boobies:
    Jul 2003
    well, id have to hear the car and noise personally. sounds liek a throw out bearing
    I think its just the cable that need to be lubricated at the pedal . my CRX did that
    Formerly Spyder Man
    Buford, Ga
    Quote Originally Posted by aaronfelipe
    could be, i figured if it was squeeking inside the car he would have been able to figure that out with out posting on a forum asking what it could be.. i may be wrong.
    :boobies:
    hey vteckidd
    I need to bring my CRX in for the clutch swap and for you to look at it,what do i need/
    Jul 2003
    Usually a throwout bearing will make the noice with the clutch depressed, no pressed in. If you press the clutch in and it makes a noice, as spyder man said, it usually is a loose spring on the clutch disk.
    if its just a quick SQUEAK when the clutch is put in, it might be a cable.
    ZERO sir2hb's Avatar
    L.B.C (little bitty calhoun)
    MIne was doing the quick squeak it was the bolt that holds the peddle was loose
    Also had another car that did the quick squeak never could figure out what it was.
    I never won any spelling bees
    Horsepower looks good on paper, Torque wins races.
    Super Ghetto Rally Team EP3sAreFun's Avatar
    Barrows
    sounds like every honda ive ever driven till i got my Si
    Mine really dosn't leave the garage. People across the street think it is a tool bench.
