Quote Originally Posted by Identity_Crisis
there is a post in the DIY section talking about using a quart of denatured alcohol in the tank to bring down emissions.... I don't have any experience with it so I can't tell you if it works or not. I would have to say it sounds like your car needs a good tune-up though. Replace you plugs, air filter, change the oil, retard the timing a little bit, and make sure you bring the car into the testing facility good and hot. If the car isn't up to full operating temp the emissions will be significantly higher. I'm sure others will chime in with more suggestions.
thats sounds really good and the only things i can think to add is grab a couple of cans of seafoam one for the gas tank, half of a can for the crank case, and another full can to suck thru the brake booster line for the top of the motor, oh also clean the throttle body with a tooth brush and throttle body cleaner
