Results 1 to 12 of 12
Thread: battery question...?
    Exclamation battery question...?
    Car - Acura Integra
    Year - 1992
    Problem -
    ok well i wanted to know what would cause my battery light not to come on when the key is in the on position( and no the bulb is not blown...lol)
    thanks in advance
    ATL DA SQUAD MEMBER #1
    HONDA_PARTS_CLEANUP_CLICK_ME
    does the car still run fine
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    yeah exactly. ever heard of the old saying "don't fix what isn't broke?"
    Who knows?
    Quote Originally Posted by Identity_Crisis
    lol if he would have said yes that was my next reply.
    Jul 2009
    in the garage
    probably a screwed wire to the hud, or maybe just a loose connection on the terminal, try checking the interior fuses to, may help you out.
    well it kinda idles lower when it doesnt come on and my my hids and radio turn off im assuming ground off of the battery
    and thanks everybody for the repsonses...
    Jul 2009
    in the garage
    man id say that your altanator is fucked if your lights run low and radio doesnt work, but please just check your fuse box and fuses to be sure it isnt that first
    If it's got tits or tires it'll cost you money...
    Quote Originally Posted by sammyt
    its not fuses. fuse is either all or nothing. but i am in agreement with the alt. have it test.
    Southside Ridin HATCH
    Alt.
    maybe the ground or check the plug.
    more wood than noahs arc sirkus's Avatar
    Cartersville, Ga
    I had a problem like that on a 90 hatch.. the alt wasn't charging full power.. but it would charge the batt enough to not kill the car while driving. Battery light would come on after driving for 10 mins and the lights/radio would die. Bass from the system would make my lights cut off and make the car skip and miss. lol
    Get the batt tested and see if it's still holding a good charge.. then try replace the alt.. and if it doesnt fix it.. return it and then start checking grounds. GL
    2014 | Hyundai Veloster | Turbo R-Spec
    while the car is running, take the neg. terminal off the battery. if its dies, its the alternator.
