Originally Posted by
EmminoDaGreat
Ok here is a rundown, I have seen many people mix up plugs for IACV with many things. Make sure the plug you are using has a yel/blk and blk/blue wires on the plug. If it doesnt and you mixed it up, you may have fried some sensors.
Onto the VSS, MANY MANY times, when people swap engines the coolant from the heater hose, will drain into the vss upon removal of the engine. Check for corrosion, broken pins, or corroded, bad connector..
02 sensor, did you use a universal or a oem replacement?
