Results 1 to 10 of 10
Thread: h22 in cb7 problems
    ..unknown
    Default h22 in cb7 problems
    Ok i swapped my H22 into my 91 Accord. It turns on and drives but the problem is it won't rev past 3500 RPM. I tried switching ECUs and it still did the same thing. Does anyone have an idea what the problem is?
    Senior Member HatchHero's Avatar
    Atl
    check engine light on?? sounds like tps, is it plugged up? u might have the tps and map backwards
    All that is necessary for evil to succeed is for good men to do nothing."
    Two things a man should maintain to the highest degree
    credibility and reputation
    somewhere, GA
    check the VSS.....that will make it do the same
    '82 TE72 SR5 Sport Coupe
    3tc
    Atl
    what codes are u throwin? code 17 is vss i think, what ecu you runnin? p13? if you changed it out with known GOOD ecu i dont think its vss i think you plugged something up wrong.. how and where did you run those vtec wires to which pinout??
    ..unknown
    I changed my ecu to the p13 ecu. And yes the check engine light is on.
    Respect my Authority SilverSurfer's Avatar
    The Barracks
    are u using the f series wire harness or the h series one
    edit: cb7tuner.com can probably help you out too
    somewhere, GA
    Quote Originally Posted by Big_Joe
    whats the code broseph????
    3tc
    ..unknown
    I'm using the F series wiring harness. and i haven't went to check what codes is it giving.
    buy me some STP octane booster whatever210's Avatar
    MCD
    go check codes. ur in the dark without knowing. and the f22 wiring harnest fine. u have to run knock sensor and vtec solinoid wire
    Atl
    bring bak codes just jump the pigtail and count
