Results 1 to 9 of 9
Thread: sr20 crank shaft
    Now you see me...... rbsilvia's Avatar
    Default sr20 crank shaft
    Will a sr20de crank work in a sr20det???? My sr is blown and the sr20de cranks are less $$$ than the det!!!!! can any one answer this quesion????/
    no nissan person but im going to say no
    JDM TYTE AnthonyF's Avatar
    Cumming
    I will have to say no also. B/c those are 2 different engines correct? One is made for boost and the other is not. I would stick with the OEM DET crank.
    -Ant.
    The Carbon Fibered R6
    buy me some STP octane booster whatever210's Avatar
    MCD
    yes. i believe they are the same.
    MCD
    they are 100% the same
    Quote Originally Posted by whatever210
    thers your answer a nissan person has spoken.
    roflcopter V-Spec II
    Norcross
    WAIT. You need to look this up. The Nissan people I'm with (including me) say most likely not. Search on Zilvia.net but DO NOT POST.
    Quote Originally Posted by MongolPup
    DO NOT POST.
    lol i love that
    MCD
    SR20DE vs. SR20DET (Remember 'T' is for Turbo)
    Here are the differences between the DET and the DE:
    The DET has oil squirter piston coolers
    The DET has a bigger oil pump.
    The DET has a different front pulley.
    The DET has lower compression pistons (8.3:1 vs 9.5:1).
    The DET has bigger injectors.
    The DET has direct ignition.
    The DET has a variable intake cam, runs retarded at idle, advanced mid range and retarded top end.
    The DET has mechanical shim in bucket type lifters with a slightly bigger in duration exhaust cam.
    but all in all everything is swappable just different in strength and or compression. you get where im going
