Thread: integra frontend damage
    roberta
    Default integra frontend damage
    ok im thinkin about buying a 1995 integra that was in a wreck but has a little damage,im replacing the rad support.my question is about the apron the support connects to it got folded pretty good,would it be easier to try and straighten it out or cut and weld in a good one? its the section right at the abs and airbox
    thanks,josh
    Athens/ATL
    folded apron?
    Cut and weld if you have the skill to do so. You'll be grateful you did.
    why did you attach an image of a clean Ls?
    rolla rollin
    middle GA
    to point out where it is folded! i looked at the car with him and i think it would be better to cut and weld it as it is bent up pretty bad
    IA Member dc 4eva guy's Avatar
    Carrollton
    cut and weld my friend, you might as well go ahead so you dont run in to any problems later.
    JDM TYTE AnthonyF's Avatar
    Cumming
    take a picture of the actual damage.
    -Ant.
    The Carbon Fibered R6
    perfect time for an ITR front end conversion
    roberta
    Quote Originally Posted by Benefit
    to simply describe where the damage is
    Apr 2003
    It may come down to personal preference. It seems like cutting and rewelding would be the "cleanest" route to go. Even if you get a good pull on the folded area, you would still have to hammer and dolley (sp) the area and it still would not look visually appealing when popping your hood.
    99 Acura Integra
