Thread: battery light on and idle hunting?
    east atlanta
    Default battery light on and idle hunting?
    i got a 88 crx hf..and tonight the battery light came on...and then the revs started jumpin up and down a few hundred rpms. after 15 or so minutes..i reved it up to like 5k and it started to go away. then the light went off at a red light..and the revs went back to normal..what the hell??
    EF Squad
    hmm weird. try cleaning ur iacv yet? any CEL on?
    DUH-KYOO-LUHHH
    sounds like the alternator is starting to go. like its not charging at low rpms.
    east atlanta
    yeah..it's weird. no cel. just the battery light. and yeah...i guess the alternator is prob goin out. its just weird that the idle was hunting..ive never had that happen before when an alternator is goin out.
    North Augusta, SC
    It did it to me when I had a 1990 eclipse... idle hunted and would shut off if I let it get that low... The battery light would come on, as you had the key turned to ACC, it would only go off at higher RPM's...
    Back to being stock and slow
    One Curve At A Time
    I see what you did thar
    97 DX Civic w/ H22 FS
    Turbo-Wired
    East Cobb
    Quote Originally Posted by coreylol
    TRUST ME: Having had the Audi die the exact same way, it is very very likely your Alternator. I was driving along one day and let off the gas, came to a stop and battery light popped on. Was freaked out but just kept driving, couple minutes later the battery light went back off and I just forgot about it. three days later I did the same thing, slowing down to stop the battery light popped on and my volts dropped from 14 to 12. I needed to get across Cobb to Acworth from fulton so I just kept driving, when I was on 41 I was down to 9 volts and you could hear my relays clicking as they were running out of juice. It sucked.
    Pull the alt and have it bench tested at slow speeds as well as high. If it checks out it might be wiring.
    east atlanta
    the light came back on...now it's not goin off unless i rev it really hard. so i'm guessin the alternator is pretty much shot.
    North Augusta, SC
    Yeah, you need to get an ALT. asap...
