Results 1 to 20 of 20
Thread: 94 civic clutch question
    Scottish Scotsman's Avatar
    on the road to recovery
    Default 94 civic clutch question
    my buddy has a 94 EG manual , he had a "buddy" put in a "new" clutch about a year ago. car ran fine for about two months , then all of a sudden no clutch. car has sat for 8 months , it fires up fine and idles like it should . here comes the part , i got in the car , started it and put clutch in and went through all the gears , everything went well(small grind when i tried reverse , but it went in) well , lol i took my foot off the clutch and again i went through the gears , no problem right , buhahahahaha , please tell me why when the car is runnin i can shift the gears clutchless? , i did check the fluid and it was full , i also saw no leaks( by cyl and under the dash behind the pedals) , i am leanin towards a shot clutch , or no alignment tool used , what are ya'll thoughts , thanx in advance
    splines ripped off the clutch disk?
    Turbo City USA
    Diff explded or broken axles is my guess.
    Quote Originally Posted by OG-Skinny
    axles were put on after he parked the car , so they are brand new
    hold on u can shift it without holding the clutch
    Quote Originally Posted by no mo hondas
    like 18 wheeler shift or speed shift. does slip at all.
    hummm....Sounds like something inside, what you need to do is take the tranny out an inspect the clutch, if checks out fine might be inside the tranny....But I think its something to do with the clutch disc.....Sorry man not to much help,most shops will tell you to if the slave is moving 100% that its inside they must take apart to inspect whats causing you this problem...Guessing threw a car forum isnt the way to fix it , but taking it apart after checking the slave for movement is...Best of luck man .Let me know if I can help
    ttt
    ^^ I think My advice is going to be the only option for you my friend!
    Sorry man if your Hydro system is working just fine only other thing it can be is inside the tranny no brainer there my friend
    Quote Originally Posted by Tech5
    pretty much
    Turbo City USA
    It would help if you tell us, DOES THE CAR EVEN MOVE?
    it will free roll , but with clutch it doesnt
    bad tranny!
    bad tranny!
    the kid wants me to do the work( i can do the swap) just wasnt sure on what he needed to buy , thanx and reps to all that put in input
    *update* jacked up the car and the drivers side axle was not in all the way , doh , i couldnt see that when i posted thread , it runs graet , thanx again fellas!
    that is what i did , on the initial inspection , i couldnt see the drivers side from the top
    Woodstock, Ga
    wooooooooooooooooooooooow lol scotsman you should know better lol....
    Quote Originally Posted by Side_WayzZX
    watch your mouth rookie , it is hard to see the drivers axle from teh top ,and i do know better
