Thread: VSS help
    The crack
    Default VSS help
    Will the VSS harness/plug off a d15b7 work on a d16z6 motor? My speedo works not at all and I replaced the VSS itself
    Senior Member | IA Veteran Mad Mike's Avatar
    Gainesville
    I think all the D series VSS are the same. The plugs should all be the same.
    check the connectors for corrosion, and or breaking off... or not making connection properly..
    The crack
    Thanks guys reps to y'all "like y'all need them"
