Results 1 to 5 of 5
Thread: Quick question about camber
    Default Quick question about camber
    ok so i have negative camber and im purchasing new tires soon. im on the market for a camber kit for the front and rear. i hear skunk 2 camber kits are good but i was wondering.. dont they all do the same job? whats the difference between an ebay camber kit and skunk 2? any suggestions on what to get?
    Jay_Bird JayL's Avatar
    McDonough, Ga
    option A:
    go buy a name brand front and rear camber kit. (most expensive, but most reliable)
    option B:
    go buy off brand (ebay shit) front and rear camber kit. (made cheap, might last you, might not, you pay to play....)
    option C:
    go order a front camber kit either off brand or name brand and using a bolt and washers, camber out your rear spindles. (cheap fix, cheap car.. its your image, not mine)
    option D:
    leave the negative camber and replace your tires every 15k miles..
    ^true. if i get a camber kit would it be a good idea to get some skunk2 lca's also?
    McDonough, Ga
    a set of lca would not be a bad idea, they can help with camber, and will improve the stability of the suspension.
    ^ ok thanks alot. reps
