Results 41 to 80 of 93
Thread: starting problem
  1. #41
    Senior Member JDM onlyy's Avatar
    Jonesboro/Stockbridge
    Check your grounds. You might have messed one up when you were cleaning the engine bay. It would cause it not to turn over.
    Theres one on the thermostat, one on the tranny, and one on the valve cover. Look for them
  2. #42
    J.R
    Down South
    Quote Originally Posted by JDM onlyy
    GOOD INFO
  3. #43
    J.R
    Down South
    Quote Originally Posted by yunglaosta
    replace your distributor...or maybe you put the distributor in the wrong way
    Naw def not and since you ask bout it i lookt at the before pic and its the right way Thanks anyway
  4. #44
    So how's it coming?
  5. #45
    Quote Originally Posted by NOCLUE
    well it prob is the starter my boi is takeing it to autozone 2 b tested 2 mar
    I think this is the problem. Look at that broken English. I highly doubt you know what you're doing with your car. Take it to a shop.
  6. #46
    LS Resurrection
    Fulton County, Union City
    are you sure you positioned in the exact same way back in? well heres something i just thought about, try jumping your car. maybe not getting power some how lol
  7. #47
    J.R
    Down South
    We did and it started but sounded real bad and the belts were moveing super slow
  8. #48
    Where was your idle at? What sounds did it make?
  9. #49
    LS Resurrection
    i think you got a bad ground then. hell, idk, i think its time for a motor swap lol
  10. #50
    J.R
    Down South
    LOL LOL HELL YA MAN GOT A LS 2
  11. #51
    J.R
    Down South
    You can hear an electrical type sound then it starts to fade away
  12. #52
    LS Resurrection
    when you took out the dizzy what else did you take out?
  13. #53
    J.R
    Down South
    thats all, i cant remember if i took off the batt cables when i took if off and put it bak on
  14. #54
    LS Resurrection
    if you took the battery off then did you put the battery terminals on the right way?
  15. #55
    J.R
    Down South
    LOL, ya man
  16. #56
    Southside Ridin HATCH
    looks to me you F'd up your timing bro!!
    Any luck man??
  17. #57
    LS Resurrection
    Quote Originally Posted by Black4DrEK
    Any luck man??
    shit if so, he got to redo his timing, try that man.
  18. #58
    J.R
    Down South
    how you do that
  19. #59
    Newbie Photodude RBS's Avatar
    All Over U S A
    how you do that
    calling someone that knows what their doing ....
  20. #60
    J.R
    Down South
    since your a smart ass whats your number
  21. #61
    All Over U S A
    theres no need for you to call to figure out how to check your timing, read carefully
    have a 10 and 17mm socket. 6inch extension and a 3/8 ratchet .. and some other small tools handy
    -disconnect battery, turn steering wheel all the way to the left.
    -remove valve cover and upper cam cover exposing the cam gear.
    -take the 17mm and the extension.. and turn the crank pulley counter clockwise until a wee little line next to 3 other lines line up with a little tab poking out the lower timing cover.
    -then look at the cam GEAR and make sure that where it says UP is facing... UP. if it is up then pretty much your good.... no need to get in depth with this unless the UP is facing somewhere besides UP
    if UP isnt UP then timing is off... very simple
    if all of that seems like gibberish to you, then calling me wouldove been pointless to begin with.
    i wasnt being a smart ass, im really trying to help you from causing more problems by attempting to fix timing when it prolly isnt even off
  22. #62
    J.R
    Down South
    thanks, if the engine turns then the timeing cant be off, it turned a couple of times before it died on me not good turns but it sounded like it was about to start but just sounded
  23. #63
    turbos
    did you put the dizzy in 180 degrees out of time......take the dizzy off and turn the key 180 degrees and put it back in..........its worth a shot and will only take 2 minutes to do
    TOO BIG
  24. #64
    yea ren you probly put the dizzy in ^180 degrees turned... Did you do what 1siccEJ2 said?
    Hit me up fool!
  25. #65
    Quote Originally Posted by seanrg1116
    Hit me up fool!
    i thought i asked that
    ooo wait i did
    Quote Originally Posted by no mo hondas
    stupid question but did u install it right with the key ways on the dizzy.
  26. #66
    J.R
    Down South
    Will do
  27. #67
    J.R
    Down South
    I got the spark plugs out and turned it over by hand, so idk its the time thats wrong
  28. #68
    J.R
    Down South
    Hit me up fool!
    if all else fails i will, cuz i got to get a new vale cover gasket to do that
  29. #69
    y?
  30. #70
    J.R
    Down South
    (Black4DrEK)
    (1siccEJ2 said)
    (NOCLUE)
  31. #71
    DBlock
    tha ville
    you have NOCLUE whats going on do you!!!! (no pun intended).....1
  32. #72
    J.R
    Down South
    J.R
    Down South
    Some eyes
  34. #74
    J.R
    Down South
    geting new ones
  35. #75
    All Over U S A
    does the car get fuel? like... is the fuel filter not clogged?
    and are you sure its not getting spark? have you actually took a plug out, stuck a spark plug in the plug and layed it on the engine and try to crank to see if it sparks?
    if you have spark, and you have gas... theres only one thing left, and thats air... or timing
  36. #76
    i drive slow im_hung's Avatar
    location, location
    here you go bro... i forgot all about it... this is from Honda's iN Network...
    http://www.zshare.net/image/557444694db2dbb9/
  37. #77
    J.R
    Down South
    Quote Originally Posted by 1siccEJ2
    spark and gas i will check today
  38. #78
    J.R
    Down South
    about to post a vid of the electric noise i was tell all you about
  39. #79
    LS Resurrection
    post it!
  40. #80
    J.R
    Down South
    srry on it now
