Results 1 to 11 of 11
Thread: fresh engine sputtering
    Default fresh engine sputtering
    i started up my engine that we just built. everything went fine up until about 30 miles in now the car sputter and when i give it gas it hesitates really bad. it idles low. I cleaned the spark plug and it idles a little better now but it still sputtering and hesitates. any suggestions?
    GECKO SQUAD
    Banned STRteg's Avatar
    Oct 2008
    Somewhere in the USA
    Info on motor?
    you set the timing right?
    replace all the plugs/plug wires/distcap/rotor button?
    my car is doing some pretty crazy stuff, after setting the timing about 4 times and it was dead on everytime, i finally replaced all the wires/plugs, cap and button and it is running fine now.
    Quote Originally Posted by rhd_civic_ej
    the timing should be right. i put brand new plugs and wires. it kinda happened all of a sudden, the car was running fine then i turned to the car off and when i turned it back on a few minutes later it was sputtering and hesitating. I dunno????
    GECKO SQUAD
    YEAH! bRiAnMcIvIcS's Avatar
    Quote Originally Posted by Skillet
    Whats up karl???
    Put some gas treatment in the tank and put some premium gas in there.
    Your gas might be bad cause your car has been sitting for months. I need to come by and check it out.
    Good Luck.
    Northwest Georgia
    nobody said the obvious.
    DID YOU TUNE IT?? NOO!!!!!!
    LS Resurrection
    Fulton County, Union City
    try replacing the distrubtor plugs. i seen it happen lots of times
    Senior Member G.C's Avatar
    Forgot
    Need more info.
    :idb:
    i think i fixxed it i swapped out some new plugs....we'll see how it rides out
    Quote Originally Posted by bRiAnMcIvIcS
    Whats up karl???
    Good Luck.
    waddup brian stop by the crib when you can to check it out
    GECKO SQUAD
    i was going to ask that
    I was just about to say.
