Results 1 to 11 of 11
Thread: fresh engine sputtering
    Douglasville
    Quote Originally Posted by rhd_civic_ej
    you set the timing right?
    replace all the plugs/plug wires/distcap/rotor button?
    my car is doing some pretty crazy stuff, after setting the timing about 4 times and it was dead on everytime, i finally replaced all the wires/plugs, cap and button and it is running fine now.
    the timing should be right. i put brand new plugs and wires. it kinda happened all of a sudden, the car was running fine then i turned to the car off and when i turned it back on a few minutes later it was sputtering and hesitating. I dunno????
    GECKO SQUAD
    YEAH! bRiAnMcIvIcS's Avatar
    Douglasville
    Quote Originally Posted by Skillet
    Whats up karl???
    Put some gas treatment in the tank and put some premium gas in there.
    Your gas might be bad cause your car has been sitting for months. I need to come by and check it out.
    Good Luck.
    Boost under slow construction...
    Douglasville
    i think i fixxed it i swapped out some new plugs....we'll see how it rides out
    Quote Originally Posted by bRiAnMcIvIcS
    Whats up karl???
    Good Luck.
    waddup brian stop by the crib when you can to check it out
    GECKO SQUAD
