Thread: Need help with parking lights
    PROJECTjdm project_EM1's Avatar
    Stockbridge, GA
    Default Need help with parking lights
    Ok here is the problem i recently installed some red and white tail lights on my hatch and now my right inner lights don't lite up when i turn on the lights.
    Head lights works, instrument lights work, brake light and reverse lights works,
    turn signals works. Basically every light works but the right inner lights do not
    light up when I turn on my parking lights. Checked all possible fuses none are blown. I noticed that my right speaker stop working too, could that be related to the problem.
    Any help is appreciated
    SoLow OutKast
    92 Civic Lx Ferio - sold
    94 Civic Dx Eg- insurance totaled
    93 Civic Si Eg6 - stolen/and striped(f**king thieves)
    00' Boosted Milano Red EM1- DD
    Road Race Junkie rogue55's Avatar
    Oct 2003
    Cumming-Gainesville
    If you checked the bulb( I'm assuming you did though you didn't say) then its either the socket or the wiring. It could be related to the speaker if both problems started at the same time. If you have a multimeter or a test light you can check this stuff. I would check to make sure the socket has good continuity to the battery ground first. Then work my way from the socket towards the fuses checking the wires for continuity. If its related to the speaker, then you would have continuity from the speaker wires to the socket or something similar to that, showing you have a short to power. The closest those wires get to each other would be under the dash, or at the fuse box I beleive.
    Anyone can drive fast in a straight line. I want to carve corners.
    Red 94 Civic #55
    National Auto Sport Association
    HPDE Driver and Corner Worker
    Working my way up to the Honda Challenge Series
    nasaproracing.com
    nasa-se.com
    hondachallenge.com
    LS Resurrection
    Fulton County, Union City
    check da bulb or light bulb socket
    soon to be fast
    socket/wire. could be a ground mebe.
