Results 1 to 7 of 7
Thread: DUAL POINT FUEL INJECTION
    IA Member 99HORSEPOWER's Avatar
    Dec 2008
    Passing you...now
    Default DUAL POINT FUEL INJECTION
    since i was wondering about putting a d16y7 into a DPFI(Dual point fuel injected) ef hatchback what do i really need to do to convert it to PGMFI?
    Don Mon SiRed94's Avatar
    Morrow 30260
    Quote Originally Posted by 99HORSEPOWER
    There are several articles online with write-ups on what all you need and how to wire it. You can stay obd0, you will just need a D16a6 distributor, and ecu. You can use the stock Y7 manifold, but it flows like shit. I'd recommend getting a Y8 or Z6 manifold/rail/injectors etc. Use your stock wiring harness and just add the wires for the other injectors and distributor.
    Dec 2008
    Passing you...now
    well the motor has the 99-00 civic intake manifold comes with the stock distributor but i am not sure which one
    and i should be getting the wiring harness and the ecu from that car
    Duluth, GA
    you still need an obd0 distributor because the chassis is obd0...
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    google mpfi swap
    Dec 2008
    Passing you...now
    Quote Originally Posted by CoOkIe-MoNsTeR
    ok thanks so which obd0 distributor could i use?
    Dec 2008
    Passing you...now
    thanks man now i know which to use
