- spec v question
master of the six speed
- Rep Power
- 22
spec v question
aight i did a search, but came up with nothing, maybe (but i hope not) one of u guys may of had the same problem, ......... so im going down the road and i look down and the oil light was blinking not like in a patern or anything, but just kinda like the wire had a short in it or something, so im thinking check the oil. so i did and the oil was just a little low so i change it, thinking that might be the problem, i used mobil one syn. k&n filter. so im going down the road after the oil change and it does it again. it doenst come on while in throttle just at idle and like i said it just blinks all crazy. and i give it a little gas i mean a very little gas and the light goes off. im stumped. so this is what im thinking....... 1. loose wire, which is what im hoping for. 2. maybe the low oil sensor messin up. or 3. the oil pump, which i hope like hell not.
- spec v question
- You may not post replies
- You may not edit your posts
Forum Rules
