Results 1 to 15 of 15
Thread: Need help trans is slipping
    griffin ga
    Default Need help trans is slipping
    I bought a beater1990 Toyota corolla dx with an automatic bought the car with the radiator missing an all the fluid had ran out the trans drained it and filled it back up problem is i've never worked on an automatic before an it drives like the clutch is slipping [Im not stupid i know it doesn't have a clutch] any ideas what would be causing this?
    Wheres the money?
    McDonough
    clutch plates in trans are burned out it needs to be rebuilt or go to a junk yard and by one from there which would be alot cheaper
    to many projects not enough money
    griffin ga
    I know the trans has come from the junkyard but it had been driving fine before it was parked i know because i rode in it bout six months before i bought it Would those discs go out that fast
    Mountain man green91's Avatar
    Dahlonega, Ga
    are you sure the fluid level is correct? youve gotta check it with the car up to temp etc and make sure its within the hot marks. if the fluid is way low it will feel like a slipping clutch also.
    1010011010 Atlblkz06's Avatar
    Hell
    ^^ That is true, first step is to check the ATF level.
    If not, just swap out the torque convertor - stop saying clutch everyone!!
    Middle, Ga
    Quote Originally Posted by Atlblkz06
    Took the words right out of my mouth. I kept wondering why everyone was saying clutch when its an automatic...lol
    "Damn, Its Tyler"
    RaceReadyDevelopments
    Dahlonega, Ga
    auto trans do have clutches.
    Wheres the money?
    McDonough
    ^^^^^ THANK YOU!!!
    GOT BOOST?
    forsyth
    its slipping there isnt much you can do...get another one
    griffin ga
    i checked the fluid cold an its over the hot mark would to much cause this
    Quote Originally Posted by 2.25teg
    No. Are you checking the fluid level with the engine running?
    Yep, that fixes it everytime.
    griffin ga
    haven`t checked it while it was running do i need to?
    Yes. It may be that when the engine is off, the converter drains back and fills the transmission, and it is actually low on fluid causing a slip situation. Always check it with the engine running. Let it run for a few minutes before you check it so the fluid can circulate.
    griffin ga
    thanks for the info gona try an check it soon as the rain stops
