Results 41 to 80 of 80
Thread: cutting springs
  1. #41
    Quote Originally Posted by TurboRiceCooker
    this is the first time i notice you not bashing. so keep up the hard work dude..
    With friends and folks with a brain, I have nice, cool discussions. With people like you, that's impossible. Later, QD.
  2. #42
    Technically I have 15 years of hands on experience
  3. #43
    Well then I could do the same thing and go on 35 years or so. But we both know that isn't right. Later, QD.
  4. #44
    Don Mon SiRed94's Avatar
    Morrow 30260
    Just take the springs out, raise the car to where you want it, then weld the shock's piston rod to the cylinder and call it a day. It will be like a go-kart, but a little larger scale.
  5. #45
    89 240 rmeyer114's Avatar
    Oct 2008
    snellville
    dont reccommend cutting springs last owner on my 240 did it and it and the ride SUCKS
  6. #46
    ATL, GA
    only noobs cut springs
    WHen it comes to cars it's better to do things once, than to half ass things and redo it over again.
    It saves time and money.
  7. #47
    Quote Originally Posted by NissanTun3r
    Ooooooooooooook. Later, QD.
  8. #48
    Gainesville
    IMO listen to what QD and Simmontibett they know what they are talking about.. as far as what i would, i would buy a set of coilovers and not be a cheap ass and risk something happen that could harm others or you...
  9. #49
    Yeah really buy eBay coilovers it's like $40, and is easier to install.
  10. #50
    DUH-KYOO-LUHHH
    wow, nissantuner said something reasonably intelligent! im impressed.
    anyways, QD has good points. heating WILL ride smoother, but on the other hand it CAN compromise the springs integrity and for an inexperienced mechanic, it most likely will not come out perfect. id say cut them. my bmw springs were cut by the P.O., who did a decent job. it sits pretty level and doesnt ride very harsh at all.
  11. #51
    ^Truth, i've ridden in it and it looks good.
  12. #52
    a tru OG,.. ask somebody
    May 2001
    lake lanier/cumming
    Well, I cut the front springs in my suburban, i cut 3/4 of a coil off to drop the front about 1 more inch. I had already lowered it 4"... I cut, because I have seen heated springs colapase after some time, and if you want to cut aftermatrket springs, most of the time it will only be 1/2-1 coil and no more..
    this is not the first time i cut springs, nor will it be the last, but i have rode in heated springs and hated it...
    Jimmy Blair II
    www.Pinnacleracing.com
    01 Tahoe w/ 'sclade stuff
    99 Grand Cherokee
  13. #53
    JDM TYTE AnthonyF's Avatar
    Cumming
    I see a lot of debate in here about cutting and heating. Heating is better than cutting. PERIOD.
    Buying the proper springs and suspension setup is better than everything. Get a nice set of coil overs with the proper springs and you will have a decent ride at whatever height you want.
    -Ant.
    The Carbon Fibered R6
  14. #54
    ^No it's not. PERIOD. You know back in the day some race teams would cut a little off race springs and play with rates, why wouldn't they heat them?
  15. #55
    lost 3'' in 3 hrs!!! 1moreaccord's Avatar
    l'ville
    Cut is best
    Seriously heat? think about the physics of that!
    The springs are made of metal.. When you heat metal it goes thru physical change to a more malleable state (depending on temp of heat). That's why the springs "lower".. The metal material is expanding..
    When metal is heated it expands and since the mass hasn't changed, then the density is changing.. The density of the metal becomes less..
    When you heat springs you are changing the properties of the metal.. IT also becomes more brittle.. = BAD!
  16. #56
    Senior Member antiv6's Avatar
    g-nett
    For the record cutting is better. If the spring is not progressive cutting will not change the spring rate but if you have progressive springs and you cut them the rate will most definitely change. Most lowering springs are progressive.
  17. #57
    DUH-KYOO-LUHHH
    heating ftl. lol
  18. #58
    ATL, GA
    DOESNT MATTER WHETHER CUTTING OR HEATING SPRINGS IS BETTER. WTF ppl.
    Buy some damn springs off ebay for like $100. If you can't spare that much money then you shouldn't be modding cars....PERIOD
  19. #59
    DUH-KYOO-LUHHH
    IMO, cut springs >>>>>>>>>>>>>>>>>>> cheap springs. i have seen the rates on ebay springs vary as much as 65lbs, and these were all bought in ONE SET.
    and a side note, if you cant pick a car thats not a mommy-mobile, you shouldnt be modding cars. dont you have some GTR pics to beat off to?
  20. #60
    You shouldn't be modding cars without the knowledge on how things work.
  21. #61
    ATL, GA
    Quote Originally Posted by Thighs
    you're an idiot
  22. #62
    ATL, GA
    That is an extremely stupid statement, and you have no facts to back up such a claim, so don't confuse yourself with me loser.
  23. #63
    Well, you are stating dumb opinions in here based off nothing, all your other post show stupidity, you told someone a special brand of an intake was junk, etc. You don't know much, if anything about cars, you are a new breed fanboy, aka F&F got you into it, maybe a magazine article about GTR, maybe a friend with a riced out car trying to pickup girls. Saying I don't know anything is dumb in its own way. I have built many more cars then you, all my jobs involved cars, and so on.
    You are obviously a dumb ass, but let the smart people talk, go back outside and play with your fake HID's.
  24. #64
    Gainesville
    IMO Skunk2 or Eibach if this is Honda
  25. #65
    DUH-KYOO-LUHHH
    explain how im an idiot? i mean, for a maxima, yours is pretty clean, and ill give you credit for that. but you have even said yourself on SEVERAL occasions that you dont know that much about cars. one of my good friends (who also drives a max...) has talked to you and he showed you his nismo "high-performance" grounding kit and you asked what it was and told him you didnt really know too much about the technical/mechanical side of cars.
    and simon is correct. my facts are backing his statement up.
    and as far as the comment about the mommy mobile and humping GTRs was all in good humor. its just teh internetz. if you cant take a joke you REALLY need to stay off IA.
  26. #66
    He failed at that quite a while ago
  27. #67
    ATL, GA
    First, you're a loser.
    Second, you probably do know more about cars than me and blah blah blah. I don't know a lot, but my knowledge grows with each mod I do, and I've went from changing brakes to swapping out my suspension, etc..Nothing major, but things take time.....
    And I told another maxima owner that an injen CAI for his car is juck, why did I say that? Because the so called injen cai sits directly behind the radiator and is in no way a cai for our cars, in fact he would lose a few hp from it.
    And my opinion about cut springs isn't based on nothing, it's fact. It is better/safer to buy aftermarket springs than to cut/heat them. Anyone who does such a thing should be slapped, and ppl whouldn't take such half-assed spproaches to modding their cars. But hey, since you obviously approve of half assing cars, more power to you loser.
  28. #68
    ATL, GA
    I don't know a lot about cars....and thanks
    And about the idiot comment, it's all in good humor. its just teh internetz. if you cant take a joke you REALLY need to stay off IA.
  29. #69
    Did anyone in here say cutting or heating was BETTER then buying springs? Truth is though some cut springs, are equally just as good as some cheap springs. But like I said, buying some springs off eBay is also the much easier way out vs cutting or heating. Cool I didn't know that about the Injen CAI. I'm not going to cry and say you are wrong. You calling me a loser for....don't know what makes you seem like a complete dumb ass which everyone here already thinks you are.
  30. #70
    Gainesville
    how about you shut the fuck up before i ban you noobcake..
  31. #71
    DUH-KYOO-LUHHH
    1. stop saying "loser". you sound like a 5th grader.
    2. there is NOTHING wrong with cut springs. there is nothing unsafe about cut springs. obviously, an aftermarket spring would be the best choice, but only from a QUALITY brand, such as eibach, tien, h&r, etc. honestly, ill keep my cut springs over a no-name ebay spring ANY day. if you knew how many competitive race cars have cut springs on them, you would be VERY surprised. you gained a littel respect admitting that you dont know much about cars, but this seems to be a topic you dont have much experience in to back up your comments.
    now go fuck a GTR in the tailpipe.
  32. #72
    ATL, GA
    you guys are funny
    when I say springs from ebay I assumed name brand with it such tein or eibach, because I don't consider no name springs an option, maybe because I don't like to half ass my suspension? Much like how I bought my tein springs off of ebay.
    But apparently I'm wrong, and everyone should cut their springs like race cars do.......
  33. #73
    Gainesville
    wow an intelligent post... im amazed and stunned
  34. #74
    IA's Speed Racer benny.boom's Avatar
    this thread is garbage...
    2008 Ford Ranger (daily driver)
    1979 BMW 320i (project car)
  35. #75
    To the newcomers (not you Simon and Thighs....I'm talking to the newer folks in this and the proven moron) that say heating springs is the worst way out, you obviously haven't read my posts. And there is nothing you can TYPE that will override my 20+ years of ACTUAL EXPERIENCE. SO throw all the "facts" that you can "think" of and I'll keep getting my propane torches out. Later, QD.
  36. #76
    you guys are funny
    You sure they are real Tein springs? Because eBay is KING of selling fake Tein springs. BTW Tein isn't that great, especially their springs. I have them on my car, and HATEEE them.
  37. #77
    ATL, GA
    I know they're are a lot of fake teins going around on ebay, and mine are authentic. I like my tein springs a lot, sucks you don't like yours.
  38. #78
    Out in the Boonies
    Well if you are going to ghetto rig that car, you might as well just ride on nothing but shocks. lol
    eBay ftw ........ well for you.
  39. #79
    Quote Originally Posted by DC2NR
    +1
    /Oo ___A___ oO\
    |=_/_______\_=|
  40. #80
    barrow county
    go with smaller rims?
