Results 41 to 59 of 59
Thread: lookin to get a tuner
    G-nett.
    Quote Originally Posted by rmeyer114
    haha i hate hondas and their little fart cans
    like this one?
    http://mx.youtube.com/watch?v=65O1alUSA7M
    89 240 rmeyer114's Avatar
    Oct 2008
    snellville
    that one precisly...fuckin hate em all
    define 6 bolt
    North Augusta, SC
    define 6 bolt
    It will be in your 1g dsm's... 90-94, a lot less chance of them crank walking.
    Regarding your question earlier about swapping the turbos. The flange on a GST is a T25 I believe, and I think that the one for a 240 is different, so you would have to get an adapter/put new flange on to make the turbo work... There are so many options to use on a 240, so I wouldn't go through the trouble to put on a stock GST turbo on it. Just my
    Back to being stock and slow
    Oct 2008
    snellville
    Regarding your question earlier about swapping the turbos. The flange on a GST is a T25 I believe, and I think that the one for a 240 is different, so you would have to get an adapter/put new flange on to make the turbo work... There are so many options to use on a 240, so I wouldn't go through the trouble to put on a stock GST turbo on it. Just my [/QUOTE]
    well i was talking about putting a stock gst turbo on a rs or gs eclipse i used to have a 97 gst spyder but i totalled it 2 years ago and havent had the money to get into another one so i was wondering if i could put one on a stock 95-99 gs or rrs
    North Augusta, SC
    well i was talking about putting a stock gst turbo on a rs or gs eclipse i used to have a 97 gst spyder but i totalled it 2 years ago and havent had the money to get into another one so i was wondering if i could put one on a stock 95-99 gs or rrs[/QUOTE]
    you can, but I wouldn't... compression is different in the NA and the factory turbo ones, it's a bigger pain in the neck than it's worth...
    North Augusta, SC
    just for more info on this...
    Most people who research this topic come to the conclusion that it is cheaper to sell the NT and purchase a turbocharged DSM, rather than attempt to convert the NT to turbocharged form. Read all about it here and here. It has been pointed out that the difference between a turbo FWD and a non-turbo FWD 1G DSM was roughly $1000 in 1998 - suffice it to say that the conversion will be significantly more than that, regardless of the method chosen.
    Weapon*R has a bolt-on turbo kit for NT 2G DSMs. The cost was $4500 last time anybody bothered to price it. At one time, Extreme Motorsports offered a similar kit that ran for only $3500, and included a 14B turbo, BOV, fuel pump, sidemount intercooler, exhaust manifold, downpipe, MBC and boost gauge in one bolt-on kit. More recently, Hahn Racecraft has taken up the challenge with their bolt-on 2G kits costing between $2500 and $3500. Note that these kits will not make your NT into a factory-turbo DSM; since the compression ratios are still different, the boost ranges are greatly restricted compared to OEM turbo engines.
    Some people have had better luck converting 1.8L DSMs to 2.0L (non-turbo) engines. Apparantly these engines are rather similar, and since there are no turbo/non-turbo issues the conversion is fairly easy - 'fairly' being of course a very subjective term. At the very least, the head and camshafts will need to be changed from SOHC to DOHC.
    Note that the above details only change a non-turbo to a non-turbo. A 1.8L to turbo conversion is likely to be at least as difficult as a 2.0 NT to turbo conversion, if not more so, since most of the above changes would have to be made prior to starting the turbo conversion.
    Some owners might think that performing an engine "swap" rather than a "conversion" would make things easier. This is not so. The engine control units (ECUs) for the NT and T engines are different, as are the engine/ECU wiring harnesses. Therefore, to properly swap in a turbo engine into a non-turbo chassis, the ECU and wiring harness must be replaced with the turbo versions.
    Additionally, an engine swap by itself is no trivial task, especially if the replacement engine requires work prior to installation. The FWD and AWD flywheels are different, and there may be other differences that prevent a turbo motor from matching up to a non-turbo chassis or driveline. While it is theoretically possible, most people would not find it worth the effort.
    Owners of 'converted' non-turbos may find the insurance to be less than a factory turbo car. This is not a guarantee, however, especially if the insurance company learns about the conversion. Those seriously interested in this conversion will find the article "Do It Yourself Turbocharging" from Overboost.com to be an interesting read.
    Quote Originally Posted by Motivation
    I could be wrong on the years, but I'm pretty sure 6 bolts only came in 90-91.
    If you got your head out of your ass, I'm bout to buy a 94 Civic EX that needs a headgasket... REALLY nice, probably want like $1500 for it.
    But yeah, my pussy ass honda is slow and has a fart can. 13.5 in the 1/4 mile is weak for a naturally aspirated 1.8 liter
    North Augusta, SC
    You're right... I believe it was the 90-91, guess I was just going with 1g for some reason.
    Whose head out of whose ass?
    The OP... lol
    Newnan
    i have a tuner..
    learn to english
    Oct 2008
    snellville
    ahhh gotcha damn well i wish my budget was a little higher lol
    North Augusta, SC
    search craigslist, they come up all the time... Check out the flea market section here too... Always good deals popping up.
    Oct 2008
    snellville
    yeah ive been up craigslists ass lookin for something im really tryin to trade the vehicle i got but so far no good lol
    North Augusta, SC
    What car do you have now?
    Oct 2008
    snellville
    i got a dodge dakota lifted 2" on 31s v6 5spd single cab 4x4 ...1992
    turbos
    With a 27 over and the loss of ur license u need somethin slow till u turn 21. I recommend a Geo METRO.
    lol get a 240 or a civic. or save like a mofo until u get ur license back and go get something nice
    TOO BIG
    Whatever you get, don't speed in it.
    Oct 2008
    snellville
    haha yeah im trying to stay clear of trouble i currently have 5 speeding tickets 2 of which being 27 over within 3 years, and i also have a D.U.I that i recieved on my 19th birthday a couple months ago ...so im trying to steer clear of any trouble for the next few years the law loves to fuck me
    Oct 2008
    snellville
    ended up getting a 89 240 with a 91 motor and 91 front end on it
