Thread: civic gas problem..
    Ap2
    Default civic gas problem..
    hey i'm having some problems with my civic right now...recently it doesn't want to pump gas anymore..so i change the fuel pump and it ran for like a day...but now when i turn it on it shuts off....sometimes i can hear it pumping but the majority of the time it doesn't pump....
    i'm thinking its the ecu or some wires because when i unplug and plug the ecu it pumps right after....
    please help... need it running again
    Project RB.
    Southside
    Check your grounds and fuses, underneath the hood
    Ap2
    checked all those...i checked all wires too
    Project RB.
    griffin
    check the pump relay under the dash
    check the main relay
    JDM TYTE AnthonyF's Avatar
    Cumming
    When you turn the key to the ON position, the pump will only stay on for about 2-5 seconds. It will automatically turn off if you do not attempt to start it right up. If you are attempting to start it and still wont fire, check to make sure you are getting fuel to your fuel rail.
    Could be something as easy as your fuel filter.
    -Ant.
    The Carbon Fibered R6
    Don Mon SiRed94's Avatar
    Morrow 30260
    Quote Originally Posted by mp82
    yes
    インテグラ K20Z1's Avatar
    Buford
    make sure you have enough vtec fluid
    Ap2
    thanks you guys gonna check it out...i think it is the fuel pump relay
    Project RB.
