Results 1 to 9 of 9
Thread: b16 tranny help
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    Default b16 tranny help
    got a car that is setup for hydro tranny, is there any way to convert to cable tranny?
    98 Acura Integra LS-DD
    ??????????????????-project
    y do u want to convert down
    TALKING ROCK, GA
    cause i found a good deal on a cable tranny b16 and i need a b series tranny asap
    TALKING ROCK, GA
    anyone?
    Where Am I
    Don't do it cable tranny's are weird in my opinion, IDK they some taking used to....
    TALKING ROCK, GA
    yeah, well i got a good deal on b16 tranny for 200 but its cable...
    cashed a 240 cashed240's Avatar
    chattanooga, tn
    yes, i believe place racing or hasport makes a hydro to cable conv. It basically turns your slave cylinder vertical in line with the arm on the cable tranny. you have to drill a hole in the arm about halfway down and it has some kind of eyebolt that you use to push the arm up and down like the cable only your slave is below the arm pushing up!
    ya there is... You can rig it and bolt the slave to the tranny 12mm's and have it push on the release fork, will work like a charm... seen it done a few. But optimumly buy the kit..
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    the kits come with the upper tranny mount and either a bolt into the arm kit that replaces the counter weight in the arm or you can cut the arm and install the hasport eyebolt kit and they all make the slave cylinder inline.
