Thread: 98 civic dx water pump
    The Roman Wardog The_ CaneCorso's Avatar
    Covington
    Default 98 civic dx water pump
    Where is it? I am going to replace it and the thermostat. Car has 200k miles on it and I should go ahead and replace the 2.
    Boost+84mm=FUN! carbon_crash's Avatar
    Loganville
    look on the timing belt side of your motor. bout half way down right below the head. Water pump is ran off ur timing belt.
    Ballin' on a Budget
    Covington
    i guess I should change the timing belt too. Never done i. So should I ge a marker and mrk where he cam is so when i put he new belt on I can line it up.
    Loganville
    good rule of thumb, change timing belt and water pump every 100k miles.
    u have markings on your cam gear as well as your crank pulley u can line up for timing. You need to go grab a Haynes repair manual at Autozone, and start reading. It will asnwer most of your preventative maintance questions
    Ballin' on a Budget
    building the new ef revized_DX's Avatar
    northeast ga
    you sure you want to take this on? good luck on it!
    Covington
    Where is the thermostat at?
    Covington
    grrrrrrrr found theromstat, cant get bottom bolt off, starting to strip
    Loganville
    Quote Originally Posted by The_ CaneCorso
    where are u located?
    Ballin' on a Budget
    Covington
    covington butt I work in lawrenceville. Got the top half cover off of he timing belt, then saw ALL the crap I had to take off the get to bottom half. I just gave up.
