does, your engine light come on?
Check ur ignition coil, located inside the distributor, see if it has the correct ohm readings (use a electrical tachometer to test). Check your spark plugs (if not fouled), then check each spark plug wires (with the electrical tach, for correct readings) see if not shorted, and check dist. cap and rotor. I'd advise using the helms manual or Factory man.
