Results 1 to 3 of 3
Thread: 95 integra need help
    Rome,Ga
    Default 95 integra need help
    i just rebuild my integra gsr with a b18 in a si tranny but for some reason at low rpm it want to act like its misfirin so we came up with a solution it was the distributer so we change that then it ran good but this morning got in it start doing the same thing so what could make the distributer go bad ??//
    It's all about JDM.
    CA to GA
    does, your engine light come on?
    Check ur ignition coil, located inside the distributor, see if it has the correct ohm readings (use a electrical tachometer to test). Check your spark plugs (if not fouled), then check each spark plug wires (with the electrical tach, for correct readings) see if not shorted, and check dist. cap and rotor. I'd advise using the helms manual or Factory man.
    It's all about JDM.
    CA to GA
    If you ain't got a helms.or factry man. pM me, I can probably post it on here.
